My Canon ImageRunner 3300 displays an error code of E000002-0000 and
says to turn copier off and then back on to clear the error. Turning it off
does not fix the error.
Ont. Panel, press the following, one after the other, * (additional functions), 2, 8, * (additional functions). You are now in Service Mode. Touch the Function Tab, touch the Clear button, touch the ERR button, when it is highlighted, press the OK button at the botton of screen. Power Cylce unit. If it comes back up, may have been a fluke. However, if it comes back, check your Fixing Assy for jammed paper, or damage to the Fixing Film (Upper Roller). Replacing the Film is not hard. After you remove the Fixing Assy., its a couple cables and springs. Rather on the easy side for Film replacements. Remebmer, on these models, the Film is also the Heater and Upper Fixing Roller. The Film is most likely on the pricey side for new, believe you can find rebuilds. Just keep in mind that the Film is still a lil' bit cheaper then the whole assy., and 8 out 10 times, its the Film that fails in the asssy
How to solve the problem
Printing time sound wheel drum Image runner IR3300
Hi. That error is related to the fixing unit. You need to clear it from service mode first.
You need to be quick doing the next process because machine will automatically turn off after a few minutes.
With the copier turned on press the next key secuence
Press adittional function
Press 2 and 8 ( at the same time )
Press additional function.
Service mode should appear in the screen . If it doesn't repeat the secuence until it does .
When service mode appears press in the touch panel COPIER
Then select FUNCTION
Then select CLEAR
then select in the lower list ERR
Then press ok in the lower corner
Turn off the machine from main Switch. Wait a few seconds and turn it on again .
Try to make some copies . If error persist there is a malfunction in the fixing heater and need to be replaced
YES THANKS A LOT
I get the Error Code: E000005-0000 when I power on the machine. It's very annoying. Can anyone out there help me out?
Canon IR 3300 switchs on it displays the Error code E000602-0003
E000002-000 error code for canon iR3035
Receive same error code e-000002-0000. Willnot reset
I pressed the additional function *and 2 and 8 and additional function * still nothing happens. My model is iR3025. So I have to shut it down again.
Error code E00002-0000 Screen says to call representative for service. Tried "* Add Func 2 8 * Add Func" and nothing happens. Screen msg stays the same.
i have same problem
how to solve error code E000002-0000
ir 3300 canon with error code 00010 please hw do i clear dis error
we are facing a problem with error code
we are facing a problem with error code E000002
But it comes on the screen code Downoad mode
