Televison & Video Logo
Posted on Apr 18, 2010
I need a 4 didit code for my remote for my neon telly
My telly is a 37 inch neon
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Jun 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
6622
Points
11
Neon are a brand made by Cello.
This is from their FAQ page here
http://www.celloelectronics.com/faqs#
"There are no codes available for the Sky remote controls, however due to a high demand from customer’s Cello have been working on a new remote control design which will be supplied with the latest range of TV’s as well as being available to purchase from Contrast Technology. This modern design will work with all 73 and 51 series LCD TV’s that use the RC08 and 09 remote handset and will operate the following satellite boxes:
  • Sky Digital
  • Sky Plus
  • Sky HD Plus"
Lost my remote for my vizio 37 inch tv
buy a replacement remote find code in code book with tv u have with remote and manuel.
Does not turn on new battery in the remote. sensor light on telly blinks all the time.
Now,telly power LED light indicator on the LCD telly panel blinks all the time now?Yes,than the telly power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.U in a European countries right?Talk to the customer service,before u buy that refurbish power supply board.Make sure it work for European cofigeration set,like 240v power supply.
Video input
Hi the only slight chancer you have of doing this without the remote and this will only work with some tellys is to have the telly switched on then the device you have connected to the video input have this switched off at the wall then with the telly on switch the device on your trying to get the telly to pick up now some tellys will pick up the signal and go to that input channel, if how ever this dont work your going to need to go out and buy an all in 1 remote, these remotes cost next to nothing to buy you can get them off the well known auction site or from your nearest cheap shop such as discount stores that sell goods for next to nothing these remotes will work on all tellys and would solve your problem if the way i told you dont work.
Im sorry their is no easy way to get it to change but without the remote your pretty much stuck unless on the telly you have a button that looks like a square with an arrow running from left to right if you have this button then pressing this wil change the input source for you, if you dont have this then the only option would be an all 4 1 remote.
let me know how you get on or if you need further assistance ok
I need a list of codes to reprogram a universal remote for magnavox televisions.
hi, please could you let me know the make and model number of your remote, this may be written under where the battery goes as each model will have a different setup option.
if you do have the manual but dont have the codes then what you can do is an auto scan where you keep pressing the standby button until the telly turns off you then save it at that point then the remote should work the telly, if you dont have manual then let me know ok
i need to know if its made by ge or rct etc as their are a few people who make them
CLICK HERE
you may find the manual or codes here
here is the guide for an rca universal remote follow these instructions to scan through all the codes on the remote and save it when you come to the correct one, this is for rca how ever their are many other universal remotes so this may or may not work
1 turn on the target device, in your case this will be the telly
2 press and hold code search until the led lights light up
3 release the code search button
4 press and release the component button you wish to program in your case this will be tv it should flash then light back up and remain lit
5 press and hold the code search button until your tv tuns off then let go and press enter to save the code.
now if your remote is and rca one then keep doing this until the telly turns off then press enter and you should then be able to control the telly with the remote, if how ever this is not the instructions for your remote then let me know what make the remote is ok.
4helpful
Can't find a code for my ver 6 sky remote for LG50PS3000 TV
on your remote:
TV,
red + select (blinks twice)
TV,
0056,
press VOLUME button if this does not work press TV then repeat
once the VOLUME button works your telly press the SELECT button (stores the code).
If this does not work its because you have a rev 6 remote. take the cover off the battery case and it will tell you the rev number.
I install sky day in day out and ive only had one LG telly that did not accept this 0056 LG manufactor code.
The HD rev 8 remote will work no problem if you follow my steps..
Hope this Helps
Little Dish Fitter
Sky TV REMOTE WILL NOT WORK MY LG tv RZ 37LZ55 ,NEED A CODE ....TRIED ALL CODES NON WORK !!
Hello Kenny
Please follow the steps below with you Sky remote.
TV,
RED + SELECT (flashes twice)
TV
0056
Try the volume button if this works then press the SELECT button on the remote. If not press the TV button and try the volume again. repeat this step until the volume works the tv then remember to press the SELECT button to save the code to the remote.
If for any reason this does not work then what I would like you to do is take the battery cover off the remote. You will see a label on there stating what REV 4,6,8 it is. The numbers indicate how old the sky remote is. If your LG telly is a newer tv then you may need to purchase a newer Rev sky remote.
The above should sort you out no Problem Kenny
When it does please leave a thumbs up
Cheers
Little Dish Fitter
3answers
Tevion TV with no compatible universal remotes
Check out eBay to see if someone has a remote for sale. This is not a name brand TV set, and therefore there is probably no support for service and parts.
If you decide to change TV sets, stay with the big name brands, and check them out for after sales support and service.
Jerry G.
Code 4 universal remote controller
need to know what kind of television it is, the codes match the component not the remote, i have the codes for about every type of tv.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
