Euro-Pro Shark GI490 Iron Logo
Posted on Apr 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
Anonymous
Level 3:
  • Master 1,871 Answers
  • Posted on Apr 18, 2010
Anonymous
Master
Level 3:
Answers
1871
Questions
Helped
492243
Points
5139
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
PLEASE RATE !
The base of our Sunbeam Pro Steam iron has become very stained and we want to clean it. What do we use?
To clean the base (soleplate) first, make sure your iron is completely cool before cleaning.
There are a number of things to remove various stains. For general stains rub the bottom of the iron with table salt and a soft damp cloth. For marks left by limescale (a powderey white) use undiluted white vinegar on a soft cloth. Some stubborn stains can be removed with a paste made from baking soda and water. What ever you use make sure you rinse and wipe the soleplate dry before using again. Never under any circumstances use a metal scouring pad or wire wool type cleaner, this will scratch, mark, and probably damage the soleplate beyond repair.
Swan steam iron 2200w
To descale make a solution of 3 parts distilled water to one part white vinegar, about a teacup full and pour into the irons water reservoir. Switch the iron on and set it on to the highest steam setting. Place a clean tea towel or similar on the ironing board and steam-clean it with the iron for a few minutes. The vinegar/distilled water solution will break down and expel the lime scale. Turn off the iron (unplug). Pour out the water and vinegar solution. Pour clean distilled water into the iron reservoir and steam-clean a new clean cloth for a few minutes. this will remove any residual vinegar etc. Turn off and unplug the iron and pour out the remaining water. Descale completed.
Nov 30, 2013 • Irons
How do I descale my iron
Oct 29, 2013 • Irons
1helpful
Iron has dark streaks
there is an iron sole plate cleaner on the market
the stain is electrolysis from using other that de-ionized or distilled water
It is leaking water when ironing all the time to the point that it stains the clothes
Remove the top part and check for the leak. If plastic has been damaged then you must use some good bonding material to close the gap/leak. However if the leak seems to come from over filling , redduce level of water, or from a gasket on the filling part.
Please look carefully into this in the ironing position with the power OFF.
Hope this helps . Good day
1helpful
Iron Blck & Decker: model D2020. I would like to clean my iron because is stared to stain all my clothes. I just open the white plastic parte on the back, but i dont see any other screws or how to get...
No need to dismantle the iron. Just fill it with a 50/50 white vinegar/distilled water solution and allow the iron to expel all of it as steam. Rinse with distilled water and allow to pass as steam. If you use distilled water from now on, you should no longer have staining problems. Hope this helps!
2answers
Tefal steam iron cleaning
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Leaking iron
Here is a tip that will help tou figure out your problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
1helpful
Black water coming out and staining clothes
Hi , couple of soloutions
black water could mean that the scale inside needs flushing out (follow instructions from manufacturer)
or it could be the inside of the iron has deteriorated that it is past cleaning
Sep 16, 2009 • Irons
Top Euro-Pro Irons Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
