HDLP61W151 turns on then off front power switch blinks. I had replaced the color wheel because of the load noise. It powers up, the menu or picture show briefly then it powers off and the power switch blinks. It will then cycle like this 2 more times, then shut off completely. At startup the color wheel spins, the philips bulb comes on and both fans turn on. Any thoughts? I've searched thru many forums but have been unable to find a complete description of this problem. Thanks
I have call RCA about the problem, and the power light blinks 3 times (not 5 times as would be for the bulb), they told me that the problem code indicates, too high or too of voltage. Would that be a transformer perhaps?
ThanksI have call RCA about the problem, and the power light blinks 3 times (not 5 times as would be for the bulb), they told me that the problem code indicates, too high or too of voltage. Would that be a transformer perhaps?
Thanks
You can't post conmments that contain an email address.
Encompass Parts Distribution 1-800-638-3328
Problem is the Color Wheel PN#212184 Model HDLP61W151yx1
Look on Ebay-under Electronics TV/Parts type in Part Number.
No,this tv have a colors wheel,it dead.The tv turn black&white,make loud grinding sound,make loud noises like a motor.All indication the colors wheel is spinning off of it axis motor and not functioning anymore.Hire a tv tech.to replaced the colors wheel,very difficult to replaced,many machanicals parts to take out,before even can see the colors wheel to replaced.
You need to replace the Color Wheel this is Normal for Samsung. Encompass Parts Distribution did have them 1-800-638-3328 whinning noise is the Color Wheel and if you have never replaced Lam do so Got mine on E-Bay for $85.00 Mats has them for 99.00
1-800-628-1118
If you hear a squeeling noise, then that would be your color wheel. When you replaced the lamp, did you reset the lamp hours? Did you check the power from ballast with a voltmeter to see if you are getting power to the lamp?
The color wheel if bad enough, will cause the lamp not to light. If the lamp is truly bad, you can't usually tell by just looking at it unless of course it is broken.
Most of the time when these sets won't turn off it's caused by the DMD but check the color wheel connectors first, especially the flat ribbon cable. Make sure it's in the connector in the correct direction, only has contacts on one side and make sure the ribbon is not torn.
there are three commom problems with this set one is light engine color wheel or power supply to get any of those is hard they are in back order but on some cases if the power is bad this could be fix bad caps on it if you want to get deep on it e-mail me [email protected]
Thanks
