There can be more than one reasons for that. 1. Broken wire at sync terminal. 2. Electronic sync issue: 2.1. Faulty sync thyristor (CR02). 2.2. Faulty trigger transformer 2.3. Any other passive component around the previous two. 3. Broken sync lead to the flash tube. 4. Broken leads to the main terminals of the flash tube. 5. Electronic fault at main thyristor. 5.1.Faulty main thyristor. 6. Faulty flash tube. 7. Other, like crack on the PCB. Good luck! :) If you happen to decide to part with your faulty flash, please consider to write me first, I offer it a good home... best regards, Laszlo klaci(at)index(dot)hu
The 544 connects to a camera via the PC cord (in this case "PC" has nothing to do with personal computers). The D3000 doesn't have a PC port, so you have to use something like the AS-15. The AS-15 mounts onto the hot shoe on top of the camera and provides a PC port.
ifyour nikon has a hotshoe it should work quite well. I use sunpak flash on both canon and olympus without any problems. Just connect to hotshoe and shoot.
All photo shops hold "hotshoe to PC" adapters for a few bucks. This solves your problem, supposed you have the hosehold-to-PC cable that comes with the 544 as accessory. If not, such cable can be obtained at better photo shops or from www.paramountcords.com. You must know that the flash can be used together with your camera only in Aperture Priority or Manual mode (flash set to auto), or as a fill flash (flash set to Power Ratio mode). The 544 has safe sync voltage.
where get battery pack for sunpack 3600 and cost please
