When you go outside, do you change anything in the settings? I think the camera should be in the auto, sport or something like that. If it is not in auto but in the night Scenery, night Portrait or high Sensitivity, pictures inside, with less light will be ok, but outside they will be over blown.
This seems to be a software problem with your camera. Your camera should, if on AUTO mode, automatically expose your photo accurately. Try half pressing the shutter button (used to take pictures) while outside to adjust focus and exposure, then press the button fully to take picture. If your camera cannot adjust to take a properly exposed picture (not bright white), then it is possible that the shutter speed is stuck on a too high speed, outside daytime shutter speed should be fast (1/1000 sec). Or if your shutter speed adjust accurately, it could be the aperture if the aperture is not small enough for daylight shooting. This is likely a software problem. Try adjusting your settings manually and see if the picture turns out!
This problem may occur if camera got too much bright inside the lens. Try to turn off the flash light and try to avoid taking picture in front of direct light, sun or lamp.
You may have the settings wrong. Check in the MENU to see if you have it set to "inside" pics rather than outside. Also the ISO has a lot to do with the exposure. If the iso is set too low outside sunlight pics will be white or overexposed. Try setting ISO on wheel for various options select program mode button and MENU select ISO 120 or 250. These are are pretty general settings. the flash will only engage inside or outside if the light is low ( like evening) I suspect your ISO setting is at a setting that is incompatible with bright sunlight t Also select White Balance and move it to DAYLIGHT
take a few shots inside and out to see if there is an improvement.
I can not use my camera when taking pictures outside .it just shows up too bright. I
don't know what I did as I have taken picture before.Can someone tell me
how to find the correct setting menu?
Scene too bright, or white balance not set correctly or shutter not held down halfway to get camera set for a picture. White screen means excessive brightness.
you need to adjust the exposure for that camera. since having too much light makes the photo all white.
Exposure and Focus
Just as with film, a digital camera has to control the amount of light that reaches the sensor. The two components it uses to do this, the aperture and shutter speed, are also present on conventional cameras.
Aperture: The size of the opening in the camera. The aperture is automatic in most digital cameras, but some allow manual adjustment to give professionals and hobbyists more control over the final image.
Shutter speed: The amount of time that light can pass through the aperture. Unlike film, the light sensor in a digital camera can be reset electronically, so digital cameras have a digital shutter rather than a mechanical shutter.
