Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
Posted on Apr 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Scanning to PDF format.
What setting do I change to get my Brothers MFC-240C to scan into a PDF file with Windows 7. It works with my laptop running Windows XP but can't get it to work on my desktop.
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 132 Answers
  • Posted on Apr 20, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
132
Questions
0
Helped
65211
Points
384
I know that the Brother MFC-7840W came with a program called PaperPort, which will allow you to scan 1 or more documents into a PDF file. Perhaps your scanner supplied the same program.
Anonymous
Level 2:
Scholar:
  • Expert 119 Answers
  • Posted on Apr 23, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
119
Questions
0
Helped
42451
Points
326
You can scan single PDF file using the ADF.
How do I name and save a scanned document in HP C4480 (Windows)?
Hello, Robert -
I hope I am correct in assuming you have the user's manual for the HP Photosmart C4480. Just in case you do not, this is the link to the web page where you can download and save the manual (PDF format - Adobe Acrobat Reader software needed, free):
https://support.hp.com/us-en/product/hp-photosmart-c4400-all-in-one-printer-series/3655558/model/3655559/manuals
After downloading the PDF document save it (Save As) to your Documents folder and give it a name you can find again easily - maybe: HP Photosmart C4480 Manual.
How to save a PDF file:
- With your computer, open the PDF document in Adobe Acrobat Reader
- Move cursor to upper left corner of page and left click or tap on FILE
- In drop down File menu, move cursor to SAVE AS and left click or tap on it
- In Save As window which opens, move cursor down to CHOOSE A DIFFERENT FOLDER and left click on tap on that "button"
- In window which opens choose DOCUMENTS in the Documents Library
- In File name box near the bottom of the Documents Library pop-up window, enter the name with which you want to save the PDF document, Example: HP Photosmart C4480 Manual
- Left click or tap on the SAVE button
Note: The steps above will be similar to what you will need to do after scanning any document.
The instructions for scanning start in Chapter 10, Page 64 (Image 304 of the PDF format manual).
Open the scanner through your computer. It is easier to save the document later by operating the scan functions through your computer.
With the scan application open on your computer run the scan process. After scanning the document, you will need to save it. First, you will need to determine the format in which you want to save the scanned document: PDF, JPEG (photo image), GIF, etc.
After choosing the format for the scanned document, in the proper file name box, enter the name for the document you wish to save.
Examples:
Correspondence 2018-Feb-18 Brother
Photo Brothers-Family 2018-Feb-18
Deed of Sale 2018-Feb-18 House
Get the idea? I like to give a date to my scanned document names to help identify them better.
Once you have entered the file name, click or tap on the SAVE button.
Note: I always like to open the saved document from the Documents folder to verify it was saved. Plus, my scanner attaches a number at the end of every file name. After closing out the saved document and closing the scanner winder, I go back and Edit the file name, removing the added number (digits) from the saved file name.
The video you will find with this link:
http://esvideo.es/video/watch/ult2ORqN1eGRiLQ=
is for those who use Windows 8 or 10. Even if you use another Windows operating system (I use Windows 7), you can probably figure out what to do. The video goes through the scanning and saving process step-by-step.
Best wishes.
I have a new laptop with Windows 8.1 (lucky me). I can't seem to get my Brother MFC 7860 DW to preform its normal scanning in pdf format.
you can try this solution : first scan to picture file and after convert it to a pdf file with a pdf printer like this one : http://www.bullzip.com/products/pdf/info.php
or try to find an update to the software (for the printer) at brother.com here :
http://support.brother.com/g/b/downloadtop.aspx?c=us_ot&lang=en&prod=mfc7860dw_all
hope it helps..... if not then return here ...
I have the Brother MFC-240C printer connected to by laptop. I have Vista 64. The printer works but I cannot scan, it says connecting to computer but nothing ever happens. What do i do?
First do you have the full software installed? Select your version of Vista (32- or 64- bit) here: http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc240c_all
If you attached the USB cable to the computer and the printer before installing the full software, uninstall the generic driver that you have running and then unplug the USB cable before installing the full software. (Generic OS drivers often only run the printer on an all-in-one.)
Next replace the USB cable (scanning requires bi-directional communication and thus can fail when the printer works). If you have a USB hub or print server, try a direct connection. Try starting your scan from the computer. (Launch the software (PaperPort SE) and hit the scan button, if your installation CD had a Vista compatible version. Otherwise, try to scan in Paint (File > Import from Camera or Scanner) or Windows Fax and Scan (New Scan))
Next make sure that the monitor program is running if you want to launch the scans from the unit. This is the ControlCenter 3 - and you need to set the destination buttons for the scanner in the software. Look for the Device Button tab for each of the scan icons in the software.
I hope this helps.
Does the briothers mfc 8840d scan directly to a pdf
well if you got a software disk from brother when you bought the printer if that has a scaning program o it install the disc on your computer and open it, put the paper on the scanner and view the advanced settings on the scan program if it has any otherwise search the settings and find the extension or format that it saves in and change it to what you prefer
Switching to a new
Hi There
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
Click LINK= http://www.4all2sell.com/pdf/Brother-MFC-240C-Manual.pdf
You will need a adobe reader to see this file If you not got an PDF reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
3helpful
Not able to scan to pdf file with Brother MFC-240C
What you seem to want to do is not possible. Let me explain:
A file that has its data in the Adobe company Portable Document Format (or a pdf file) contains various objects that are described to the computer using a superset of the PostScript language, some of them can be images.
A file that comes from the scanner is first a very organized set of pixels and gets put into a more compact form by using a well known process as defined by the Joint Motion Picture Experts group. This is a roundabout way of saying that it has a format that isn't PDF.
What you CAN do:
a) open the jpeg file with a Macintosh, using the Print command from the file menu make a pdf file that has the image in it.
b) buy and install a PDF printer driver on a Windows machine, and then follow the same process as A above.
c) Use your favorite PDF creation program to make a file with the image embedded.
Carl
How to change to a higher resolution on a mfc-240c
Hi tammy, you can either use the Windows printer driver which will allow you to set scanning resolution up to 1200 dpi which you can access through a program like Photoshop (File--Import) or the Brother Scanner Utility to go up to 19200 dpi resolution. If for some reason you don't have the scanner utility on your computer, you may have to install it from the disc that came with MFC-240. If you need further help let me know.
Scan Photos
u put ur picture on glass of scanner . and give command to scanne after scanning computer will ask in which format u like to save ur file
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
