Microsoft Windows 2000 for PC Logo
Posted on Apr 19, 2010
Bad DirectSound driver. Error code 88780078 - Microsoft Windows 2000 for PC
Anonymous
Level 1:
New Friend:
  • Contributor 31 Answers
  • Posted on May 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
31
Questions
0
Helped
22807
Points
71
The sound card features might be turned off and causing Error Code: 88780078.
To activate these "features":
1)control panel
2)sounds and audio devices
3)Hardware tab
4)sound card should be listed... highlight... Properties
5)Properties tab
6)Audio Devices
7)highlight sound card and click Properties
8)If audio features are disabled... select "Use audio features on this device"
9)restart computer
3helpful
Bad direct sound driver please install proper drivers or select another device in configuration error:88780078
It's a common issue and easy to fix. Take a look at this blog post, the kid did a good job of explaining http://blogote.com/2010/windows-ideas/fix-bad-directsound-driver-error-code-88780078-in-windows-xp.html
11helpful
Bad directsound driver . error code: 88780078
Assuming you are running windows XP, you can follow this link to ert your drivers:
http://support.asus.com/download/download.aspx?SLanguage=en-us
4helpful
Error code 88780078
Try replace Dirctsound driver.
Use method below for you sound.
http://taszara.com/solved-bad-directsound-driver-error-code-88780078/92/
3helpful
Bad direct sound driver error 88780078
1.) Open Winamp
2.) Press and hold down Ctrl+P (for preferences)
3.) Go to Plug-ins --> Output
4.) Double click on "DirectSound output"
5.) Click on the Driver tab
6.) Make sure the device in the drop-down list correctly reflects your soundcard.
Further DirectSound config tweaks....
http://forums.winamp.com/showthread.php?...
This may just do it for you folks...please leave rating, thank you kindly
2helpful
Hp 530 laptop - Bad directsound driver error code 88780078
sounds like the sound card is dying, or the sound codec's are wrong.
2helpful
Bad DirectSound driver. Error code:88780078
check the sound drivers in device manager. if it gives yellow sign then re-install sound drivers.
2answers
M2N-MX sound
Try reinstalling the drivers, which can be found here.
23helpful
6answers
DirectSound output v 2.2.6 error, error code 88780078
hello,
I have a problem with my computer.I have installed win xp and my audio driver is not working well.It returns this error code 88780078 .i can't uninstall it,i've tryied to reinstall win xp...same error .the computer is brand new and don't know what is the problem...please help me
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
