When inserting r4 card and switching on it comes on screen with loading then underneath says : system date error! please check NDS system date.
it won't do anything. it's ok with normal games and was working one minute then switched it on next time and this happened and keeps happening
It's a bug issue in the firmware of the R4 cards. Won't work after 14 april 2010 unless you update the firmware of the R4 card.
For the time being you can set back the date before 14 april 2010 and it wil work directly.
gr
Hi...
Push in the reset button ( it's very small) and reset your date and time
or..Pull the battery and wait 10 minutes..then reset all the user functions
Got the fix! Yesterday (31/April) I was doing a Google search on the R4i "System Date Error" problem and found the permanent solution! Basically one that DOESN'T involve changing your system date to one that it's not! Check out this blog post:
http://www.nds-gear.co.uk/blog/2010/05/nds-gear-solves-r4i-sdhc-system-date-error-problem/
Follow the instructions and use their software (for genuine R4i-SDHC cards only of course) and problem should be solved! Worked for me on a regular DSi console with the original R4i SDHC card, 4GB memory.
