This is the t-con err, you can check the LVDS cable connections, if no problem, replace the t-con board or panel.This is the t-con err, you can check the LVDS cable connections, if no problem, replace the t-con board or panel.
You can't post conmments that contain an email address.
I would suspect one or more of the miniature flourescent backlight lamps. One way to confirm this would be to power up the set with a grayscale image at 40 to 60 IRE. If one or more lamps is failing to light, a slightly darker horizontal area in the grayscale will give it away. Unfortunately, Sony will not supply any of the backlight components apart from a new LCD panel. Sorry.
you can have the inverter board replaced...instead of the entire panel.
KDL 40S2010: inverter part # 178950032, you will also need 2 spacers..part # 289765511
you're looking @ 200-300$ for the inverter and 5-10$ a piece for the spacers.
KDL-46V2500: inverter part # A1251295B you're looking @ around 500-600 $ for the part
