LG Flatron L1715S 17" LCD Monitor Logo
Posted on Apr 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am using LG L177WSB. Few days before a vertical blue line is appearing many times along the screen whenever i switch the monitor on for more then 3 hours continuously.
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Apr 20, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366081
Points
33650
The LCD panel is failing, bad T-CON board which is built-in part of the panel, it will get worst, new LCD panel will be needed.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
My lg lcd got a pink vertical line on its right hand side and it is getting bright day by day .my lcd is LG FLATRON L177WSB. is any solution pls get me out of dis ..................
What you have is a row of "stuck" pixels. Do a google search for a utility that will "repair stuck pixels" I have used them with very limited success. Your chances are better if it is just one or two but you have whole row. That says to me it's a bad transistor somewhere.
Here is a video that shows how the 'unsticking" process works with a web link.
http://www.metacafe.com/watch/366558/stuck_pixels_in_lcd_fix_em_now/
You are probably looking at buying a new screen.
6helpful
Hi, i have AL1716 monitor (2 year old). Recently, there is a blue vertical line which appears on and off sometimes in the monitor. Can anyone suggest on a solution
Is the vertical line always at one location ? (on the screen)
If so, it appears that the video card/driver (on your PC or laptop) may be causing the line to appear occasionally ... i.e. flaky ... and it will likely fail (completely) in due time. To confirm it's the video card, try using another monitor (long enough) to see if it happens.
[ The line may also be caused by "dead" pixel on the screen ... but this usually happens on randomly located pixels on the screen, not on one vertical line. But, it may also be a possibility ... in which case, using a different monitor may prove it one way or the other ]
2answers
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
Monitor is blueish
If the Blueish problem appears try play around with the VGA cord and see if the Colors comes back, if not, try hiting the monitor to see if the lines and color problem comes bcak to normal. If not your monitor's circuit board needs some dry solder, it could be the cold solder problem. Cheers.
1helpful
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Single vertical red line
Hello Monastirion,
Is the red line there all of the time without exception, for instance when you initially turn on your pc, is it there before the operating system boots?
If so, the monitor itself is most likely broken. I would return it to wherever you bought it, if possible.
Regards,
-Chester
10helpful
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
3helpful
7answers
A pink vertical line appears suddenly on the screen
i have a samsung 15inch monitor.which is only 6month old.giving blue vertical line along the right side of monitor (almost 2 inches from right side) how to remove it plz someone help me.my mail id is [email protected] you..
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
