A squealing noise during the sensing cycle of your Maytag top-load washer can be caused by a number of factors. Here are some common reasons and steps you can take to resolve the issue:
Loose belt - The noise could be caused by a loose or worn belt that needs to be tightened or replaced. You may need to remove the front panel of the washer to access the belt.
Idler pulley - If the idler pulley that keeps tension on the belt is worn or damaged, it can cause a squealing noise. Replace the idler pulley if necessary.
Bearing - A worn bearing in the tub can cause a squealing noise. Replacing the bearing will typically require disassembling the washer.
Drive motor - If the drive motor is worn or damaged, it can cause a squealing noise. Replace the drive motor if necessary.
If you're not comfortable diagnosing and repairing the issue yourself, it's best to contact a qualified appliance repair technician for assistance.
first check the house breaker and make sure you still have power. If it does then I would unplug the machine and lean it back against the wall to look at the motor wiring harness underneath to see if it came loose or is wet.
See if my Clutch Fix post will help. I also have links to Service Manual which will be big help. The drive belt can be walked on the Clutch Pulley but it is a very snug fit even with the drive belt tension bolt loosened. Watch you fingers as you walk the drive belt onto the clutch pulley….Rich
Hello sunny31,
If you believe the belt is slipping then the belt will need to be removed and replaced. There aren't any belt tensioners in your washer.. Can you provide the specific model # with a response so I can provide you with more information on how to resolve your problem?
Regards,
Rick
