This is a common problem with many LCD monitors. The
printed circuit board that provides a stable voltage for the monitor to operate
from starts to fail. The PCB can be replaced, when/if they are available, or repaired
in most cases at a much lower cost. for more information on this email me at
[email protected]
What is the model number of this monitor? Does it do the same with other PC? Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:http://s807.photobucket.com/home/budm/al... Post back what you see inside so we can guide you further and it will help out other people in the future also.http://www.badcaps.nethttp://en.wikipedia.org/wiki/Capacitor_p...
