My washer is slowly leaking water from bottom . Found a puddle of water undeneath while cleaning ran a load thru and it leaks from the bottom!
Either the hoses are cut or the drum seal is bad
Check the hose is still attached and if not reattach obviously (best to add a hose clamp as well to hold it in place, you can get these from any hardware store). If its attached it could be something as simple as a split hose, the smallest hole will leak a huge amount so check for that, if it is that again a hardware store will have a replacement hose that you can replace it with.
Hi this helen i would like to know how do i stop the water from leaking at the bottom
