These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others. You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D *Colors wont align *Screen may look distorted or warped *No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
inside the light engine there is a red a green and a blue glass color filter.The heat from the lamp causes the color to burn off the glass.You need new filters .One is red one is blue and one is green.The lcd itself doesnt make the color,it is a black and white device.The colr comes from light shining through colored glass
Go to menue on controller, then Picture, then adjust Color and Tint to you taste. The color ajusts Blue and Green move left more blue move the slider right more green. The Tint controlls red. More red move right less left. Also chech Color temp setting.
If you have a screen that gets "tints" of various colors on a corner or edge, check that the monitor plugin cable is not near or laying on top of a power cable, the magnetic field around a power cord will cause a monitor to get strange tints or lines in the screen. Option two if the entire screen has a tint equally all over it is possibly the color is out of adjustment or failing - a technician should be able to adjust it internally.
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
Fresh Contrast: Off
Noise Reduction: Medium
Gamma: Medium
Black Level: Low
Real Cinema: On
TruMotion: Low
Color Standard: HD (N/A w/HDMI)
White Balance: Warm
**Method: 10-Point IRE
10 IRE
**Red: 1
**Green: 2
**Blue: -16
20 IRE
**Red: -6
**Green: 0
**Blue: -7
30 IRE
**Red: -5
**Green: 0
**Blue: -4
40 IRE
**Red: -8
**Green: 0
**Blue: -4
50 IRE
**Red: -4
**Green: 4
**Blue: -4
60 IRE
**Red: -6
**Green: 6
**Blue: -5
70 IRE
**Red: -8
**Green: 3
**Blue: -10
80 IRE
**Red: -8
**Green: 7
**Blue: -16
90 IRE
**Red: -9
**Green: 5
**Blue: -18
100 IRE
**Red: -10
**Green: 4
**Blue: -9
Color Management System
Red Color: 0
Red Tint: 0
Green Color: 0
Green Tint: -15
Blue Color: 0
Blue Tint: 11
Yellow Color: 15
Yellow Tint: 2
Cyan Color: -15
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it. im isf certified those settings are right on the money straighter than a ruler
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
