On most of thiem there is a hatch right behind the front seats on the floor look around see if u see were little piece of the carpet folds back u will see a bold loosen it to lower tire
Hello, this vehicle has a locking device to keep the spare tire from falling down. you will have to perform these steps to remove spare tire.
Turn the folding wrench clockwise to raise the jack until it lifts the secondary latch device under the wheel plate.
Keep raising the jack until the compact spare tire stops moving upward and is held firmly in place. This lets you know that the secondary latch has released.
Lower the jack by turning the folding wrench counterclockwise. Keep lowering the jack until the compact spare tire is resting on the folding wrench
Rotate the hoist shaft counterclockwise in order to lower the spare
tire to the ground. Continue to rotate the shaft until the spare tire
can be pulled out from under the vehicle and removed. If the spare tire
does not lower to the ground, the secondary latch is engaged causing
the tire not to lower.
If the secondary latch is engaged and the cable end is visible, perform the following procedure:
3.1.
Tighten
the cable by rotating the hoist shaft clockwise until you hear 2 clicks
or feel it skip twice. You cannot overtighten the cable.
3.2.
Loosen the cable by rotating the hoist shaft counterclockwise 3 or 4 turns.
3.3.
If the spare tire can be lowered, repeat steps 1 and 2 to see if the spare tire can be removed.
3.4.
If
the spare tire cannot be lowered, rotate the hoist shaft
counterclockwise until approximately 15 cm (6 in) of cable is exposed.
3.5.
Raise and support the vehicle.
3.6.
Place a transmission jack, or equivalent, under the spare tire.
3.7.
Position
the center of the transmission jack under the secondary latch release
button at the center of the spare tire. Arrange the arms of the
transmission jack so they will support the tire after it has been
released.
3.8.
Raise the jack until the spare tire stops moving upward and is firmly held in place, releasing the secondary latch.
3.9.
Lower
the tire. If the spare tire is hanging by the cable, rotate the hoist
shaft counterclockwise until the tire is low enough to remove.
If the spare tire does not lower to the ground,the secondary latch is engaged causing the tire not to lower Your vehicle has an underbody-mounted tire hoist assembly equipped with a secondary latch system.It is designed to stop the spare tire from suddenly falling off your vehicle if the cable holding the spare tire is damaged.For the secondary latch to work,the tire must be stored with the valve stem pointing up. 1.Check under the vehicle to see if the cable is visible.If it is not visible proceed to Step 6. 2.If visible,first try to tighten the cable by turning the wheel wrench clockwise until you hear two clicks or feel it skip twice.You cannot overtighten the cable. 3.Loosen the cable by turning the wheel wrench counterclockwise three or four turns. 4.Repeat this procedure at least two times.If the spare tire lowers to the ground continue with Step 2 of removing the Spare. 5.Turn the wrench counterclockwise until approximately 6 inches (15 cm) of cable is exposed. 6.Attach the jack handle,extension and the wheel wrench to the jack and place it under the vehicle towards the front of the rear bumper.Position the center lift point of the jack under the center of the spare tire. 7.Turn the wrench clockwise to raise the jack until it lifts the end fitting. 8.Continue raising the jack until the spare tire stops moving upward and is held firmly in place. 9.Lower the jack by turning the wheel wrench counterclockwise.Keep lowering the jack until the spare tire slides off the jack or is hanging by the cable. 10.Disconnect the jack handle from the jack and carefully remove the jack.Use one hand to push against the spare while firmly pulling the jack out from under the spare tire with the other hand.
your post was cut short, but cable that holds the spare in place is what I think u were asking, and that would be what u call it, 'the cable that secures the spare tire, or lowers the spare tire'
