Re: We want our ricoh aficio 2015 as a network printer...
First u have to purchase feature expantion or GW board from ricoh if it has been already installed in d machine just download the rpcs driver from www.ricoh.com
and install to ur pc
Try this:
Operation functions
ok
System settings
ok
Interface
ok
Change de IP and the sub-mask
ok.
In the and click ok to programe the information.
Hope you understand
In order to connect it to a network, you need to have the print/scan option installed. If your copier has the print/scan option, you can hook it up with an Ethernet cable and download the print driver from the Ricoh website:
This is all you need to upgrade your copier to a network printer/scanner and fax. Good Luck.
32MB Memory Unit Type B 400516 Postscript 3 kit type 1045 410713 64MB Memory Unit Type B 400517 Fax Function Upgrade Type 185 410284 Print Unit Type 1045 410706 Printer/Scanner Unit Type 1045 410699 Network Interface Board Type 1045 410714 Fax Option Type 1045 410680 Fax Stamp Marker Type 30 334049
If network board is installed: Press "User tools" "System setting" "interface settings" "network" "ip address" then, with "spceify" highlighted, select "ip address" Type in your preferred IP address, press 'OK'.....then be sure to select "OK" with "specify" highlighted to lock in the setting, or it will not be saved. Do the same for the Subnet mask. Then set it up on your PC.
You will need to assign a new appropriate IP address for the machine under "user tools" system settings", "Interface settings", "Ip address". Then create a new tcp/ip port for the printer, and point the old driver to this. Scanning may require additional work -perhaps a tech, to reconfigure the scanner. Your probably using the "scanrouter" software?
