Question about Watches
Quartz president wall clock, I need to set the chime
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
  • Adam Parker
    Adam Parker Aug 18, 2018
    JohnB Could you send me intructions on setting a President Westminster Chime Quartz clock please? It is around 1990. I need to set the chime. It has two slide bottoms but no press ones. Battery operated.
    New Friend:
  • 25 Answers
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Posted on Nov 03, 2010
  • 12 more comments
  • freddymazda Mar 09, 2011
    Could I take you up with the offer of a copy of these instructions please.
    From maurice.cragg@sky.com
  • rocketrobot Mar 10, 2011
    could i plz have a copy to rocketrobot@hotmail.co.uk
  • JohnB Mar 10, 2011
    Will send same as sent to freddymazda in next ten minutes - hope it helps
  • james faulkner May 29, 2011
    hi i would most greatfull for the instruction too. many thanks. jay13.faulkner@live.co.uk
  • JohnB May 30, 2011
    Just seen your request. 3 page word copy on way in next couple of minutes. Hope they are the right ones for you.
    John
    on its way
  • Chris Davies
    Chris Davies Feb 16, 2014
    Hi John B, I'm struggling with the same sort of clock it's a president wall clock with chimes, don't have any instructions. And I'm trying to stop it chiming every 15 minutes, don't have a problem with it chiming on the hour but ever 15 minutes a a bit much! Can you help?
  • rdpatel Mar 07, 2014
    Hi, John, could you please send me a copy of the instructions aswell please if you have still got it. Thanks. rdpatel@blueyonder.co.uk
    Hi John, could it be possible that you can please send me a copy of the instructions aswell if you still have them to rdpatel@blueyonder.co.uk. Thanks.
  • JohnB Mar 07, 2014
    For Chris Davies, Just seen your message, apologies for late response. My President clock has no means of choosing 15min chimes or not. You can have 1. All time chimes, 2. silent only between 11pm & 05:45am or 3. silent all the time.
    For rdpatel. Just seen your message. I am sending 3page word docx as soon as able - Email server has problems at the moment. Hope it helps. John
  • Samantha Simms Jan 16, 2019
    Please could I also have the instructions sent to me sammyloulovesstu@gmail.com as I need to know if I set it as 12 hour or not
  • James Nov 06, 2019
    Hello just seen your instructions in here. My mum has left me a president Quartz wall mounted clock. Sadly no instructions.can you send me instructions I would be gratefully appreciated. Thank you. My email address is
    jamesgibson60@hotmail.com
  • John Buery Nov 07, 2019
    Have just sent them to you James, hope they help
6ya staff
SOURCE:
MINUTE HAND NOR THE HOUR HAND NOT ADVANCING AS THEY SHOULD. CLOCK STUCK AT 8:45 FOR DAYS, PENDULUM MOVEMENT OK. WHAT IS THE SOLUTION TO GETTING THESE BACK TO WORK? THIS IS ON A STRAUSBOURG MANOR...
without seeing the clock .....are you sure it isn't something as simple as the hands ( arms) detaching from the centre spindle which continues to turn but without the hands. Alternatively have the hands become stuck on something on the clock face or become intertwined themselves ? Very simplistic but all I have to offer...
Feb 24, 2015 | Watches
I have an Elgin Westminster chime quartz wall clock (with pendulum). It uses a C-cell battery. It will not work at all. Please help if you can, since it has sentimental value to me. Don't know if...
I'm afraid you have to visit clock repair shop, as without close inspection it is not possible to say what's wrong with your clock.
May 18, 2011 | Watches
I have an Elgin Westminister Quartz Chime clock. Everything works fine, except the pendulum does not swing, anymore. Can I fix this or can I buy parts to fix this problem?
I have a clock with a pendulum and it has two batteries, one for the clock and one for the pendulum.
Perhaps your is the same?
Mar 13, 2011 | Watches
I just purchased a Heritage Mint Ltd Timepiece Quartz Regulator wall clock but it chimes two hours slower than the actual time. Need to know how to correct it. There is a red push button on the back of...
I have the same clock. Here's what I did to re-set it after changing batteries: After replacing batteries, use the turn dial to set the correct time. Press the RED button 6 times, wait for it to go through that series of chimes, then press the button again to set the time.
Example: Press RED button 6 times. Wait for it to chime. Press RED button the correct number of times for the hour to be set. For 5:00, press the button 5 times, etc.
I lost the directions to my clock, and I am posting this from memory and also just had to re-set mine and it works OK now.
Hope this helps!
Feb 07, 2011 | Watches
How do i synchronize my chimes on a westminster quartz abacus 401c wall clock
If it is like mine you press the test button until you hear the chime. Wait for the hour chime to go and count it. If it chimes once for 1PM and you need it set to 6PM then you press the test button to reset the chime and repeat press the button 5 times. This will set the chime to 6 PM. If you get lost on the time press until it makes no noise. This means you are 11PM or later and continue to then press until it makes noise again. Count the hour chimes and you are at the count in the AM. Repeat the steps and keep pressing to get to the proper AM or PM hour count..
Jan 16, 2011 | Watches
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    Elgin Westminster Quartz Chime clock won't work
    IF I GATHER CORRECTLY , YOUR CLOCK HAS TWO BATTERIES, ONE AT BASE AND ANOTHER ON THE BACK OF THE UNIT. THE ONE ON THE BACK OF THE UNIT IS RESPONSIBLE FOR CLOCK'S FUNCTIONALITY AND I THINK THE BATTERY AT BASE IS FOR THE ROTATING BALLS ( PENDULUM ). SO OPEN UP THE BACK IF YOU HAVE NOT DONE SO, AND REPLACE THE BATTERY. CAREFULLY THOUH AS THERE RE TWO SCREWS ON TOP AND A SNAP AT CENTER BOTTOM WHICH YOU COULD EASILY BREAK IF YOU DO NOT DO IT WITH CARE. OPEN UP THE SCREWS FIRST AND GENTLY USING A SCREW DRIVER PUSH BACK ON THE SNAP HOLE TO FORCE IT UPWARDS AND INWARDS. IF NONE OF THIS MAKES SENSE THEN WE ARE LOOKING AT TWO DIFFERENT CLOCKS.
    HOPE THIS HELPS.
    Sep 23, 2009 | Elgin Watches
    How can I start a small Quartz clock?
    The first thing to try would be to test the battery. If the battery is good the problem may be the mechanical works need to be started in motion. If it has swinging parts try to get them swinging. If it has hands set the time on the clock. Hold the the clock in your hand with the face towards you and rotate it clockwise a few times to get the gears moving. Sometimes just letting it sit upright for a day or so will be enough to let the clock start working. I hope this is helpful to you.
    Carol.
    Apr 12, 2009 | Watches
    Watches Logo
    3,755 people viewed this question
    Top Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
