Tomtom Go 630 GPS Receiver Logo
Posted on Apr 21, 2010
My TomTom GO 630 is frozen on locating a GPS signal. How do I reset
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Apr 30, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
1824
Points
11
Mine does this about once every couple of weeks. It just requires a "soft reset." To do this you just take a pin or paper clip and press the reset button located on the bottom of the TomTom Go 630 to the left of where you plug in your charger/usb connector. This is a "soft reset." None of your settings are changed... it's just like rebooting your computer. It just clears your temporary memory (like RAM) so all it would possibly lose is your current route if you had just set one. You probably can't since yours is frozen but DO NOT go through your device menu screens and "reset to default" because you will lose all of your settings and saved locations that way.
My tomtom has frozen at the last destination and cannot find a valid GPS signal
Have you tried to shut it down and restart it ?
Or do a "reset", using a "pin" (e.g. paper clip) to insert into the "Reset" hole at the bottom of the unit ? Then start it up again.
Apr 28, 2016 • Tomtom GPS
2helpful
What is the passcode to pair a telus cell phone with Tomtom Go630
default password for pairing any phone with tomtom go 630 is 0000. some phones require you type the password and some do not.
4helpful
2answers
Windows 7 will not recognize my tom tom go 630
Lots of folks having this problem with differernt model TomToms. It's the USB on the TomTom.
You'll need to "reset" the unit, using a paperclip or narrow pen, hold the reset button in for about 5 seconds and you should be good to go. On the 630 it's on the bottm, right next to the USB port.
Hope this helps!
Brian
No gps signal with tomtom
Solution for No GPS Signal
To pinpoint your location, you need to get signals from at least 4 satellites. If you receive signals from less than 4 satellites or the signals are not strong enough, the Driving View stays gray and one of the following messages is shown in the bottom right corner of the Driving View:
  • Waiting for a valid GPS signal
  • The GPS signal was lost sec ago
Note: In previous versions of the TomTom application the message may vary.
If you see any of these messages, try the following:
Finding a GPS signal
In the following cases it can take up to 5 minutes to find your current position:
  • You use your TomTom device for the first time.
  • You haven't used your TomTom device for a longer time.
  • Your TomTom device has been relocated without using it (e.g. after traveling by plane or train).
If it takes longer than 5 minutes, make sure that you are in an open place without tall buildings or trees around you.
Once your TomTom device has located your current position, the Driving View is shown in full color and shows your position on the map.
Tip: Most TomTom devices can use QuickGPSfix™ to locate your current position faster.
Flight mode
On devices with built-in GPRS connectivity, flight mode also disables your device’s GPS reception.
To switch flight mode off, tap Flight mode in the preferences menu and then select Restore connections.
Clear View
Your TomTom device must be outdoors to locate your current position.
Try repositioning your device in your car; ideally, try to position it at the lowest possible point directly on the windscreen.
Some vehicles have a heat reflective shield embedded in the windscreen, which may prevent your device from locating your current position. If this is the case in your vehicle, use the TomTom External Antenna Kit (available as an accessory).
Tip: As a reference, place your device outside your parked car to see if it can find your current position.
Reset your device
Reset your TomTom device. Click here to learn how to reset your device.
Install the latest application
We recommend always having the latest version of our application installed on your device.
See also: How to check for and install an updated version of the TomTom application?
3helpful
How can i get the instruction manual for the tomtom gps
Here are some locations where u can find manual for your TOMTOM GPS:
http://download.tomtom.com/open/manuals/ttwirelessgps/ttwirelessgps_uk.pdf
http://www.retrevo.com/samples/TomTom-GPS-manuals.html
1helpful
My Tomtom 130 GPS seems to be frozen.
Hello there:
first off i would consult the troubleshooting section in your users manual if you dont have it contact the manufacture of the device for a manual.
otherwise try this remove the power cord and press and hold in the reset button for 2 min this may help reset the unit.
If not remove the power cord and leave the unit sit for several hours it has a re learning function built in also if you can go to www.tomtom.com to view a downloadable users
630 tomtom dashboard afix
When I put on my Tom tom Hands signals comes on with red cross seems like Memory card accpetance problem i have done Reset click and have tried to adjust the card inside but to no avail please advise
1helpful
Problem with tom tom 520
Do a soft reset by holding the power button down for 15 seconds. then power on and off. it should work. It did for me. if not, call tomtom. they are willing to help quickly
Gps frozen on tom tom 3rd edition
can you locate the reset button and try that first.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
