Samsung LA46A550 46 in. HD-Ready LCD TV Logo
Posted on Apr 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Half of my lcd tv gets dark no picture
Hi my 14 month HD samsung 46inc lcd tv the right side gets dark with no picture after few minutes of using. thanks..
Anonymous
Level 2:
  • Expert 308 Answers
  • Posted on Apr 21, 2010
Anonymous
Expert
Level 2:
Answers
308
Questions
0
Helped
134921
Points
814
Find your warranty papers....may be a defective screen.
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
I have a 75" Samsung LED TV, and the top position of the screen is going dark, is that a power supply issue?
Samsung TV half the screen goes black or dark - YouTube
? 0:38
www.youtube.com/watch?v=Mmu5wq6LVgM
Jan 28, 2012 - Uploaded by DaReal2Face
Samsung TV half the screen goes black or dark. ... My samsung 40" - 14 months old does this on the top half of the screen. .. ****** 12 month ...
1helpful
Half the screen isa dark, left side
Most likely you have a faulty LCD panel tabs. This can be verified sometimes by turning set on and tapping or squeezing the top left side of the TV. The only true fix is to replace the panel. I've been told that Samsung may offer to replace the panel or give you a discount on a new TV. Samsung is know to have LCD panels with premature tab failure. So it may be worth while to contact Samsung and see what they can do for you. There are videos on youtube that show case the problems and show you how to patch the problem. just type in "LCD panel tab" in the youtube search box.
Samsung TV Screen faulty
t con board failed if its half and half. can also be a lose cable on the screen to the tcon board from the lcd screen side. Tcon is in the middle off the screen on the back.
2helpful
The screen on my samsung ln46a550 lcd tv is dark on the right side when I first turn it on. After about 5 to 10 minutes the right half brightens up. I also have a 3
Bad news, the LCD panel in your tv is going bad, call Samsung and complain about the problem, it is a manufacturing defect. It would cost more than a new TV to replace the "panel" or LCD screen. Good luck.
1helpful
Screen dark on right hand side at start up
Suggest return or exchange. This is a newest model, and on factory warranty, if can't return or exchange, you have to complaint it until the panel is replaced. in fact, it is 90% panel defective. right now the LCD panel quality is too bad.
1helpful
2answers
When I trun on TV (Samsung LN-T4661F 46 In), it start with half scrren dark from Right Side, time goes by being normal screen. I want to know what the problem is.
Samsung made a bad TV, the new part is $1200 I have the same issue. it is a blurred picture from left to right after about 10 min it goes away. (18 month old tv) it is only going to get worse.
Picture quality on PT-50LC14
clean out the housing (where the lamp is) the go through your menu and check the tv settings ie...color temp, picture, contrast, ect...try resetting it back to the default and go from there
3answers
Sony Videoscope XBR tv
This is usually a convergence problem.. Could you update this with the model number please. That will allow me to give you some specifics about what could be wrong and how to fix it.
Dan
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
