STRANGE THAT ALL YOUR VALVES WOULD GO BAD AT SAME TIME, I WOULD PERHAPS CHECK YOURKNOBS ( USUALLY THERE IS A SMALL METAL INSERT THE PRTECTS THE PLSCTICKNOB ITSELF, IT SOETIMES SLIPPS OF AND REMAINS ON THE VALVE STEM IF SO YOU WONT BE ABLE TO PUSH IT DOWN TO TURN IT ON, SIMPLY REMOVE THE INSERTS FORM THE STEMMS AND REINSERT THEM INTO THE KNOB IF THIS DOE INDEED SEEM TO BE THE ISSUE, OTHER THEN THAT REPLACING THE VALVES.
