We have to check the remote control first. After that check the digital picture frame.
Follow the instructions below please;
We must be sure the remote control is working;For this control:
1. Take a digital photo of this remote control while pressing the remote control button.
2. If it is working then the picture must shows the led lamp of remote control as firing.
3. If the picture does not show that it is firing, then, you should control batteries of the remote control.
4.Check the battery and the battery polarity of the remote control.
5.If it is firing. You should control Digital Picture Frame.
6. If the battery of the digital picture frame does have enough energy or not. If battery is low then you shoud use it from the closer distance.
7. I do not think that the Digital Picture Frame is out of order.
Regards.
Turn off the power, unplug the battery and all cables.
Eject the installed battery if you have one.
This will protect you against electric shock.
Find the small, round rubber screw covers and pry them off.
This will expose the small screws holding the LCD screen frame in place.
Depending on your laptop, these covers might be made of some other type of material.
Remove the frame by gently prying.
Locate the LCD screen's cable and power supply cords. Unplug them and remove any tape holding the screen in place.
Check the identify of the manufacturer on the back or side of the screen.
It may be different than your computer's manufacturer.
Since these screens look so similar, make sure you order an LCD screen that matches your manufacturer's model number, or else the new screen will not fit.
Plug in the new LCD screen, replace any tape holding the screen in place and replace the frame.
Don't pinch any wires as you press the frame back into place.
Screw the frame down and switch on the power to see if it works.
If it does, go ahead and replace the screw covers.
If it doesn't, remove the battery, the screws and the frame.
Check your connections.
If it still doesn't work, call your parts supplier and ask for assistance in getting another replacement LCD screen.
hope this helps
