Hi All. I don't know why my telephone write on dislpay " -SOS-" and everything I push, make a call to SOS number. How can I deactivate the SOS mode? Thanks advance.
If you have an android phone you can go into the google settings and change it from there. If it's Samsung you can deactivate it through your phone settings, than it's called SVoice.
<p>Open Start/Run... and type the command:<br>
<p>regedit and click "OK" (or press ENTER).<br>
<p>Go to <b>HKey_Local_Machine\Software\Microsoft\WindowsNT\Current Version\WPAEvents</B>,<br>
<p>on the right double click on "oobetimer" and change at least one digit of this value to deactivate windows.<br>
<p>Click "OK" and close the Registry Editor.<br>
<p><b> </B><br>
<p><b>%systemroot%\system32\oobe\msoobe.exe /a</B><span> </SPAN>and click "OK" (or press ENTER).<br>
<p>This will bring up the "Activate Windows" window.<br>
<p>Check the option for "Yes, I want to telephone a customer service representative to activate Windows" and click "Next"<br>
<p><b> </B><br>
<p>Then click "Change Product Key" (don
My dear friend ,don't you activate progresive scan function by mistake because if you do it you gotta deactivate. Try this turn on the dvd with no disc on the tray push for 5 sec the stop button.Good luck.
In order to set call forwarding on this telephone, must first have the feature CFV (Call Forward Variable) on in the line. This feature can be provided by the telephone service provider.
A typical feature code for this is *72 to activate CFV and *73 to deactivate.
You can program these features on the M9316 telephone by do the following:
CFV activate
1) Press the SAVE key.
2) Then select the key where you want to program the feature.
3) Then enter *72 (optional: plus the telephone number of where you want the call to forward to).
4) Press SAVE twice.
CFV deactivate
2) Then select another key where you want to program the feature.
3) Then enter *73
Be sure and label your buttons.
To use go off hook and press the key you just programmed.
No. It's a programming item and a code or softkey.
The user connects the modular headset to the handset jack on
the telephone leaving the handset in place. The ON/OFF
button on the Digital Telephone is used to initiate and end calls
while using the headset.
To activate Headset Mode:
Dial [634] on the dial pad,
-or-
Press preprogrammed HEADSET MODE button. LED lights
steady.
To deactivate Headset Mode:
-or-
Press the preprogrammed HEADSET MODE button. LED
extinguishes.
While Headset mode is active, the ON/OFF button
activates the headset and disables speakerphone
and intercom call announce operation at your
station.
To install the headset, see the Installation Manual.
Station must be programmed in database
programming for headset operation before the
flexible button can be programmed.
hi i locked my sim card, i went onto 02 website and went onto PUK code. it asks you to put your phone number in then comes up with the code. i put the code in and it it worked
For voice mail service subscribers
If you subscribe to a flat-rate service
package that includes Caller ID, call
waiting, voice mail, and unlimited
local/regional/long distance calls, please
note the following:
L To use the voice mail service provided
by your service provider/telephone
company rather than the unit's
answering system, turn off the
answering system (page 30).
L To use this unit's answering system
rather than the voice mail service
provided by your service provider/
telephone company, please contact
company to deactivate your voice mail
service.
If your service provider/telephone
company cannot do this:
- Set this unit's "Ring count"
setting so that this unit's answering
system answers calls before the
voice mail service of your service
provider/telephone company does.
It is necessary to check the number
of rings required to activate the
voice mail service provided by your
company before changing this
setting.
- Change the number of rings of the
voice mail service so that the
answering system can answer the
call first. To do so, contact your
company.
Handset? What mean?!
The problem i posted was referred to cordless phone One Touch FIRST 20, same as picture.
I don't know if is useful to know that in the battery box there is this code:
002B85C778
Atlinks
01/33
THANK YOU!
