Broken mount , aluminum die cast pivot broke off?
SAMSUNG BN44-00123A BIZET-17A 940BW BACKLIGHT INVERTER https://www.abctay.com/wholesale-original-samsung-bn4400123a-bizet17a-940bw-backlight-inverter-used-p-2056.html
Broken mount on back of monitor to base?
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
BIZET 17A Samsung BN44 00123A Power Supply Backlight Inverter
The easiest solution would be to epoxy the mount back though you may loose ability to tilt monitor, be sure not block any air holes. when setting together tape it to proper spot and let set for recommended time on epoxy(get at hardware store).
