Hi, I have a Panasonic Reverve Cycle Air Con Split system Model CS/CU E15 DKR and it hasnt been cleaned. Can I please have some info on how to clean the filters and anything else that requires cleaning. Thank You
  • Anonymous Mar 17, 2014
    How does the cover come off to clean filters on model ES9001PR
    New Friend:
  • 34 Answers
Lift front cover on indoor unit, lift up then pull out the filters and wash them with dish washing liquid in water and hose them off.
Posted on Apr 24, 2010
6ya staff
SOURCE:
I have a panasonic inverter air con. Model CU-E18LKR. it's not cooling properly. Seems to be blowing cold air out on th outside rather than inside.need instructions on troubleshooting
This is a reverse cycle (heating and cooling) model. It sounds like you have it in heating mode. Check the Panasonic website for an owners manual.
Jan 30, 2017 | Panasonic Heating & Cooling
Split system not starting up for about 10 mins after turning on
Hi Wendy,
The manual for the unit is at this link. This should answer all your questions. http://panasonic.com.au/products/details.cfm?objectID=4601 then go to the bottom of the page and click on CS/CU-E18_21_24_28HKR Operation Manual
I take the time to answer you questions so please rate me
Thankyou
Mat
Jun 10, 2009 | Panasonic MCM INVERTER
PANASONIC DUCTLESS SPLIT
Try to check the resistance of your room air and coil thermistor may be its out of range the reading of both thermistor is 8000 to 10000 ohms @ 25deg C temperature. if its higher or lower then the thermistor is out of range and need replacement. And try also to check your terminals and connector for loose.
Mar 18, 2008 | Heating & Cooling
Panasonic split system air con cs/cu-e24gkr
check the indoor unit sirkit board,there is problem.
Feb 14, 2008 | Heating & Cooling
Panasonic Split System Air Conditioning.
we have a old national air con cassette model cu-5chv11p , works for three days , then controller comes on e4 error ,and then switches off , and will not reset .
Dec 28, 2007 | Heating & Cooling
Heating & Cooling Logo
163 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
