Assuming you have a Kango of the E Type vintage, I think the
oil consistency is probably around the SAE 30 range with additives.
If someone
could identify the base consistency of the oil used in the older Kango's, then
an oil suitable for the Kango can be formulated and submitted on this website.
As for manual, I have a E Type manual booklet, the only
mention is that Special Kango oil must be used.
Also see; February 11th.
2013 item on this website regarding Kango oil.
\charlie use sewing machine oil, as for a book on it put the make model into google and a pdf might be available as for parts not really unless you sroce them through the paper or ebay
Testimonial: "This infomation is "pointing" me in the right direction. Thanks"
the old kango 900 and 950s use a mobile grease, tan in color. I have parts and service manual that I may be able to email you.
hi, have you got pinions for them?
Probably, I should at least have a good used one. However when I have had to replace the pinion I normally have to replace the ring gear. Either way you will need to reshim the ring gear or you will ruin them. send me an email.
Hi any chance that you've still got a copy of that manual? Cheers
