Question about Canon EON Elan 7NE with 28-200 lens Film Camera
Will a Minolta AF zoomlens 35-70 mm fit on a Canon
Will a Minolta AF zoomlens 35-70 mm fit on the body of a Canon EON ?
  • 302 Answers
NO.
the mounts are incompatible.
Posted on May 03, 2010
6ya staff
SOURCE:
CL) U) 28-300/3.8-6.3 AF MINOLTA what camera will this fit
Sony bought out Minolta and a lot of the old type Minolta lenses will fit on Sony cameras but not all of them.
Jul 08, 2014 | Quantaray 28-200MM F3.8-5.6 Lens for Canon...
Have many lens for XG-A what other minolta bodies will they fit
The XG-A, like the other X-series cameras, uses the older Minolta SR lens mount. You're pretty much limited to the SR- and X-series cameras. They will NOT fit the newer Maxxum bodies, for example, which use the newer Minolta AF lens mount.
Dec 19, 2012 | Photography
I have many lens for XG-A what other minolta bodies will they fit
Dec 19, 2012 | Minolta XG-A 35mm SLR Camera
Is it possible to convert a sigma lens to fit a canon body or by using an m42 adapter?
Sigma makes their lenses with a variety of mounts. If the lens has a Canon or M42 mount then there is no problem. If it has a Minolta mount, for example, then replacing the lens will be easier and just as cheap as changing the mount. If it has Nikon mount, you can buy adapters to fit it to Canon or M42 bodies.
May 12, 2012 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
If I buy a Canon EOS 500D body wil my 500n AF lens fit it and operate OK?
All canon EF and EF-S lenses work with 500D /T1i model.(yes all)
If your lens is removed from old 500N body and if it has EF marked it will work for every Digital camera model of canon.
Note: its focal length will be multiplied by 1.6 X factor.
(mean 18 mm lens will become 29mm approx.)
If you find this of help rate me.
Nov 23, 2009 | Canon EOS 500D / Digital Rebel T1i Body...
I have Quantaray 28-90 mm aspherical lens and want to know what digital bodies it would fit on.
With right adapters it should fit in any camera. At least Canon, Nikon, Minolta, Pentax. The adapters are 10-20$ each and easy to fit in the lense.
Nov 04, 2009 | Quantaray 100-300mm F4.5-6.7 Zoom Lens for...
I have a sony alpha 100 i want to buy a 1993 minolta maxxum 3xi with 35-70 and 70-300mm lenses. Those minonolta lenses are compatible with my alpha?
I took the following off of the Alpha website
"Sony Alpha lens mount
Identical to the Minolta A-type bayonet mount, enabling the use of a large back catalogue of existing Minolta and third party lenses"
I know that the lenses that fit my son's Maxxum will not fit my non-Maxxum Minolta bodies. VERIFY THAT THE LENS YOU WANT TO MATE TO YOUR SONY HAS THE MINOLTA A-TYPE MOUNT.
Oct 14, 2009 | Quantaray 50mm f/2.8 AF Tech-10 for Canon...
Minolta to Nikon --Switching to Digital -- LENSE problems
Mirror lenses have no aperture nor AF, so they mount via a T mount. A $30 item that screws on the end of a mirror lens that fits your camera. A mirror lens has it's physical likes and dislikes against a glass 500mm. A glass 500mm will give a better image if you can stop down to F8 F16. Then you have shutter speeds to consider and those lenses are usually connected to the camera's contacts. So they can be specific to a single body. There are older Tamron lenses that take Adaptall mounts, they are old and hard to find. But they solved the multiple body problems for "auto" program lenses. None had AF, when AF camera around, we were back to individual lenses per body.
Jul 25, 2009 | Sigma Telephoto 105mm f/2.8 EX Macro...
Minolta SLR Lens on Sony - Does it work.
As I understand it, Sony bought Minolta, lock, stock, and barrel. Theoretically the lenses should fit and may work on manual, but I'm very sure they will not totally work on sony digital cameras. I wouldn't even try to fit them as the autofocus system on the camera may be damaged.
Mar 22, 2009 | Tokina AF 100-300mm f/4.0 II APO Telephoto...
Used on a Minolta Maxxum 800 si
Hello
The Minolta AF lens will fit and work on most of the Minolta AF bodies (it will depend on exactly what lens it is as to the compatibility), you will also find that it will fit and work with the new range of Sony
digital SLR camera bodies.
The Quantaray lenses are a little bit more difficult as Quantaray make lenses for several different types of camera body, it should mention on the lens what make the lens mount is for. If you post further information about the lenses it might help.
Sep 19, 2008 | Quantaray 100-300mm F4.5-6.7 Zoom lens for...
Canon EON Elan 7NE with 28-200 lens Film Camera Logo
144 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
