Having an issue with my dishwasher. Some water is still left in the dishwasher after teh cycle is done. Can you please help me troubleshoot this issue? Tell me some potential causes for this and what I can do to fix the dishwasher? Can you please also send me a schematic for this dishwasher?
Thank you,
John Linta
(586) 739-3637
how do you remove the two side plates and drawer. I have undone the screws but I can not slide the unit out. The dishwasher has a blockage and I am trying to clear it.
TO SLIDE THE UNIT OUT YOU MUST UNINSTALL THE MACHINE. START BY UNSCREWING THE TOP. ANY SCREW THAT HOLD THE MACHINE IN ON TOP AND SIDES IF APPLIES. CHECK THE DRAIN AND FILL HOSE TO SEE HOW MUCH LINE YOU HAVE TO PULL OUT UNIT. IF DRAIN HOSE IS SHORT DISCONNECT FROM UNDER THE SINK. IF FILL HOSE IS SHORT TURN OFF WATER GOING INTO MACHINE AND DISCONNECT HOSE. IF ELECTRICAL IS SHORT THEN DISCONNECT FROM TERMINAL BLOCK BUT MAKE SURE THE POWER IS OFF. THAT SHOULD DO IT.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
The scum, film and white
residue problems have started since the reduction of
phosphates in dishwasher detergents.
Here is a tip that
will help you to solve the problem of films, residue, and scum in
your dishwasher.
Dishwasher
Residue and Film on Dishes
heatman101
