Hoover HCA390K Bottom Freezer Refrigerator Logo
Suzy Wall Posted on Nov 01, 2017
I have a brand new hoover black fridge freezer - only 3 days old and the freezer section is fine but i cant get the fridge to get below 7 degrees it makes no difference if i turn the dial to low or high. It is in a tight space but air is circulating on both sides and the rear what do you think is wrong or is it safe to run at 7 degrees?
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Dec 12, 2007
SOURCE: Nextra Hoover Fridge Freezer, Fridge not cold enough.
I would turn the thermostat up towards number 4.
robboatoz
  • 29 Answers
  • Posted on Aug 13, 2008
SOURCE: Hoover HCA300FK Frostfree fridge freezer
thermostat is not turning off.replace the thermostat
Anonymous
  • 9 Answers
  • Posted on Sep 06, 2008
SOURCE: Fridge does not cool below 40 degrees
This is a common problem and a design fault...
Anonymous
  • 212 Answers
  • Posted on Jun 21, 2009
SOURCE: hoover classic fridge/freezer frost free - fridge
check your vents for good air flow
Anonymous
  • 363 Answers
  • Posted on Jul 26, 2009
SOURCE: my freezer works fine, but fridge doesn't cool
It sounds like the circulating fan is wearing out. The fan circulates air thru the freezer as well as the refrigerator. When it starts to wear out the force is reduce to a point that the freezer will get cold but the refrigerator will not get cool.The minimum cost of the assemble is around $300.00
1helpful
Should I repair or just replace my Liebherr fridge/freezer
Looks like this model is now out of date and I wouldn't trust your service guy. Any service agent will know whether the door switch, thermal sensor or control panel is faulty by simply testing them. I would not have to fit complete parts to isolate the faulty part.
Sounds like he doesn't know how to or wants the job of fixing it.
Try an independant repair service, local one man repair shops tend to give an excellent service.
If you want Currys do a good range of fridge freezers; https://www.currys.co.uk/search?q=Liebherr+fridge-freezer+model+CPEL4813&search-button=&lang=en_GB
https://www.currys.co.uk/appliances/refrigeration/fridge-freezers/bosch?searchTerm=Bosch%20fridge%20freezer
https://www.currys.co.uk/appliances/refrigeration/fridge-freezers/hoover?searchTerm=hoover%20fridge%20freezer
To show just one retailer. There are many more out there. Try and buy locally if you can, you will get a better service I find.
I bought a Philips (Whirlpool) years ago and after 3 years, out of warranty, it packed up. The aluminium heat exchanger started leaking. Not worth repairing.
I now purchase Hoover. They has a 10 year parts warranty.
They are all 15 tears old now.
One gets what one pays for I suppose.
Why does Siemens KF57U56/16 Freezer works fine, but not fridge?
Check the thermostat adjustment in the fridge section if right up replace the thermostat.
Fridge won't cool past 57 degrees
Guessing ether a fan, damper our defrost issue. Sorry cant be much help.
1helpful
Frigidaire model FRS24WNF. Will not freeze (except the lower compartment of the freezer) nor transfer cold air to the refrigerator. The back panel above the coils freezes up. Once I turned off the unit...
Of necessity, this is going to be a very LONG answer, BUT... it COULD save you from buying another fridge. There could be several causes for your issue, but the most likely is a blockage [usually a buildup of "frost"] of/in the duct that carries cold air from the freezer compartment to the fridge compartment.
Not all, but MOST refrigerators work by having two controls for the two zones [freezer and fridge sections]. The first control [an actual thermostat] is for the freezer, and is what actually turns the compressor on and off. The other control is for a "damper" in the duct [or, SOMETIMES controls an in-duct FAN] from the freezer to the fridge section.
The compressor system cools the freezer, and the refrigerator section is cooled by transferring colder air from the freezer.
The freezer control should be set to keep the freezer at about minus 10 degrees Fahrenheit to about zero degrees. Then the fridge damper control [usually the control with the letters A, B, C, and D] is usually set to about the MIDDLE position, hopefully to keep the fridge section about 34 or 35 degrees to a max of about 38 degrees.
SINCE you say that the FREEZER IS operating PROPERLY, I suspect that the DUCT that is supposed to supply cold freezer air to the fridge is somehow blocked, and this is usually caused by an accumulation of FROST [frozen water VAPOR] in the duct. Note, and write down the "settings" for BOTH controls. You'll need these later to restart the fridge.
Although the "fix" is a pain in the ____ it is not that difficult. Here are the steps to correct:
1. Get one or more ice chests/coolers.
2. Remove ALL contents from the freezer and place together in one, or if necessary two of the coolers well covered by bag ice to preserve the contents. Put a couple of bowls, or anything, in the bottom first to keep the frozen stuff above water from the melting ice. Then pack the frozen stuff very tightly with as little open space as possible. Then pour crushed ice on top. Several times a day, drain the melt water from the drain on all the ice chests, and as necessary, add ice to replace that which melted.
3. Do the same thing with everything from the fridge section.
4. Then turn OFF the refrigerator, and CLEAN both the fridge and freezer VERY WELL. IF you don't clean both the freezer and fridge WELL you will get mold, mildew, and probably an offensive odor!
5. Then PROP the freezer AND fridge doors open AT LEAST a couple of inches, or MORE if possible. This will allow warmer household air inside. IF you have a portable fan to blow house air into the fridge section that will cause the frost to melt faster.
In a house with no air conditioning, in the summer, the blocked duct should thaw in well less than 24 hours. If you have air conditioning and no fan circulating air into/through the fridge it could take 2 or 3 days, but in any case, after 3 days, you should be ready to test the fridge.
6. Plug the fridge back into the wall outlet, set both the freezer thermostat and the fridge control back to their original settings when the fridge was cooling properly. [AGAIN I remind you that, at the very beginning, make note of, and write down the settings for both the freezer thermostatic control, and the fridge duct control]
7. Place a thermometer on a middle shelf of the fridge [and if possible, one in the freezer also] and check it/them after about 4 to 8 hours.
IF a frost blockage was the cause of the failure, the fridge should now be cooling properly again and when the fridge temperature gets down to below 36 or 37 degrees [F], then you can replace all the stuff into the fridge. IF none of the freezer stuff has thawed, then that can be replaced in the freezer. IF any has thawed, then cook it properly, and you can freeze it again if you want.
I know this is a lot of work, BUT... it sure is A WHOLE LOT LESS EXPENSIVE than replacing a refrigerator that DOESN'T NEED REPLACING!!!!!
3helpful
2answers
My fridge is over cooling - now freezing food
i just want to say that i have the same fridge freezer and that is whats happening to mine. even the drinks are freezing aswell as tomatoes and any other thing that is put in there. after reading your problem im thinking maybe this is a manufacturing fault. i am about to buy an extended warrenty for mine then i can get the poeple to fix it as mine is also 3yrs old. hope that helps.
11helpful
Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
1helpful
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Burnt smell inside freezer.
Generally speaking it is the refrigerator control that controls the compressor operation. Refrigerator is cooled by air from the freezer. When the refrigerator gets down to its designed temperature it shuts off the compressor. The freezer control determines how much air is allowed to flow into the refrigerator section and there-by controls the freezer temperature.
Top Hoover Refrigerators Experts
vince
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
