Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
Both the freezer section and refrigerator stopped
Both the freezer section and refrigerator suddenly stopped working. The door light still works but it doesn't come on or make noises like it is trying to work. This is a suplementary refrigerator about two years old and everything within it spoiled before we found it. Blood from meat ran from the freezer section down into the refrigerator and will have to be cleaned inside. Any guideance will be much appreciated.
  • infoinfo Nov 11, 2010
    freezer is working ok but refrigerator stopped working
    Scholar:
  • 126 Answers
YOUR REF. MAY BE STUCK IN DEFROST. IN THE CEILING OF YOUR REF. THERE IS A CONTROL HOUSING. THERE IS AN ACCESS HOLE ABOUT 6 INCHES BACK MORE OR LESS IN THAT AREA. INSIDE THIS HOLE IS A ROUND GREY, BLACK OR RED PIECE THAT CAN BE TURNED IN ONE DIRECTION WITH A FLAT BLADE SCREW DRIVER. TURN IT. IF IT STARTS YOU WILL NEED A DEFROST TIMER. NEED MORE HELP JUST ASK.
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Apr 25, 2010
  • rl bradley
    rl bradley Dec 03, 2013
    Is it possible to locate a diagram of the control housing?
    President:
  • 2,468 Answers
You need to replace the "PTC over-load relay" on the compressor body in the lower rear area of the unit as this component supplies all the power to all crictial power needs of the unit,all you need to do is unplug and replug in the replacement
Anonymous
SOURCE:
Refrigerator section stopped cooling, but the freezer section still works.
Hi. There is a valve in the top corner of the frigde that controls the cold Air to flow from the freezer to cool the fridge. This valve called a damper closes when the door is opened. You have to depress the door switch and listen for the fan in the freezer to switch on then feel for cold air to flow into the fridge compartment. The fan could have failed or the damper valve could be stuck closed.
Jun 05, 2016 | Maytag MFF2258VE
My RJ 523V-R refrigerator has worked perfectly for 8 years, but suddenly stopped cooling the fridge properly while the freezer seems ok. how can I fix this?
Often times their is a fan from the freezer section to the refrigerator section, of some brands of boxes. If the fan goes out, the refrigerator sections no longer cools.
May 23, 2014 | Electrolux Refrigerators
Amana BR22VL refrigerator section stopped cooling.
is there any frost on your food packages or on the ceiling where the light is?if so the door was left open and the air vents are froze up or you have a bad damper or evaporator fan motor,open the freezer door,do you hear the fan blowing?if so the fan motor is good,check for ice on the ceiling and packages,if that checks good look at the back inside wall of the freezer,if that's covered with like snow or frost you have a defrost problem or also you have a damper in your model,it's closed and won't open to let the cold air in from the freezer.
http://www.repairclinic.com/PartDetail/Damper/R0161050/223353
go here,this is the part,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer up into the fridge section,in your model the damper door opens to let the cold air in,when it gets cold enough the damper closes and that's it,so if the door wasn't left open and the fan is blowing in the freezer you have a bad damper.
Aug 10, 2012 | Refrigerators
Replaced 30 watt bulb in refrigerator section with 25 watt bulb still will not light otherwise working well, my be switch . freezer section light works
Either the door switch or the light socket is bad. Disconnect the refrigerator and pull the switch out and test it with an ohmmeter for continuity.
Jan 06, 2011 | Samsung RB2155SH Bottom Freezer...
Freezer thaws and then Refreezes
Theory of operation: Cold air is produced in the freezer section and is then circulated via a fan located in the freezer section. It sounds like you may have either an air leak from faulty door seals, ice dispenser door flap stuck in the open position, or the light staying on the door is closed.
A faulty compressor fan may also cause symptoms like that but you should hear the thermal cut out clicking off and on due overheating of the compressor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 10, 2017 | GE Profile 26.6 cu. ft. Side-by-Side...
Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Wirlpool referigerator's frezzor has stopped working suddenly
if your freezer has stopped freezing, hten your refrigeraotr section is also ging bad you just havent seen the chnge yet, sounds as ifyour having a sealed system isue, weather its a bad comprssor, or aleak in the freon levels. check your warr, 5 yrs full covereage form manufacture
Jan 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator stopped working, freezer works fine
I turned off the refrigerator and left the freezer door open so the coils and the vents could thaw out. The cold air was not getting to the refrigerator section because of ice blocking the vents.
May 01, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Admiral - GC2224GEKB
Does freezer cool like the cold food section? Did this suddenly happen, and frozen food began to thaw?  Most freezers control the cooling in the cold food section. The freezer must work fine before the cold food section will work fine. Let us know more, Thanks JT
Oct 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
407 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
