When I connect my S630 to a Mac or Windows PC with the cable, I am not prompted to do anything on the camera. No new devices appear on the machine. Is there a setting on the camera to "kick" it into upload mode?
Thanks for your help.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Make sure you install the supplied driver for Samsung S630.
You're supposed to be prompted by the camera to select "Connect to Computer" or Connect to Printer. Make sure "Connect to Computer" is highlighted and press the Menu/OK button.
SOURCE: samsung S630 junk
I am Judy Malone in Tenn and I had my camera all in box and ready to mail back to place listed on camera box. I had worked on camera for last few days and to no avail. I got the notice via email today and the usual steps that I've read before.
To take batteries out, insert again. And to hold the ON button to keep camera powered. Then press Center button OK and press RIGHT 3 times to Setup2...
Well, I could not get my camera to co-operate past the Press Right 3 times to setup 2. Only the usual screen with a few of the icons showing my battery had power. It would not do anything past this.
Well, I got mad...(smile) and figured something had to be wrong as it kept showing a 32 for picts and I knew I had taken 414 at least on my Lexar 512 MB (SD).
I thought something must not be aleigned properly..some pins inside or somthing, so I GENTLE tapped the camera against my kitchen table... First one side, then the other..and GUESS WHAT. My camera came to life and has been working fine since. I HOPE this is a permanent fix...as I love the camera and have said so.
So, for what it's worth...try this if everything else seems to fail...but please do it gently. And start from the beginning.
Take batteries out, then reinsert...and GOOD LUCK.
I will post again...and let you know if this continues to work.
I am amazed.
judy in Tenn
SOURCE: uploading pictures from my digital camera onto my computer
everytime i plug my camera in the usb it dosnt want to upload pics?
I appreciate REL123's suggestion, but I do not have the driver CD for my computer (Mac OS X) because it was misplaced in a move. Any chance someone can tell me where to get it? Samsung only posted the Windows driver on their website, as far as I can see.
Thanks in advance.
--Glen
glenmy (at) gmail (dot) com
