SNK Magnavox 19MF338B/27 19 in. LCD TV Logo
Posted on Apr 26, 2010
Magnavox 19MF338B/F7 TV fine yesterday, today no picture
My magnavox 19MF338B/F7 TV worked fine yesterday, today only the menu screens flash randomly. no picture, no sound.
Bro. James
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 07, 2013
Bro. James
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1076
Points
A capacitor needs replacing, I fixed one I found in someones trash that had the same problem, A 330 microfarad capacitor (uf) rated at 16v (the damamaged cap just had a bubble shaped foil top that indicated it went bad. replaced it with another cap (high voltage rated for tv replacement cap) cost 1.99 and it all works Great!
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jul 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
3231
Points
8
Chinese piece of ****.
1helpful
Magnavox 46" LCD TV shuts itself off after a random amount of time.
Is there a person in your environs who is mischievous or prone to malfeasance? Someone may be using a TV-B-Gone on you. Check this out:
https://cornfieldelectronics.com/tvbgone/tvbg.home.php
Magnavox 19mf338b/f7 no picture but sound ok
Check its backlight inverter board. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2300 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
How to scan for channels
Go to page EN-23 of the link for instructions.
http://download.m4c.magnavox.com/files/1/19mf338b_27/19mf338b_27_dfu_aen.pdf
I have a 19" magnavox
Do you have a digital converter box. If not, you need to get one to receive the analog channels.
2helpful
3answers
Magnavox 32MF321D no audio
Hi my name is Roety,
I can help you with your issue ,
You can check the setting for stereo/sap must be set to stereo
If all connections are good and the problem is inside the Tv you will need a new mainboard (or SSB, scaler), ck encompassparts.com
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
1helpful
Magnavox 42 inch flat panel cannot get a picture
TV may need software upgrade. Go to menu, find instalation, find software upgrade, find. If version is bellow FL2D-r23 (#23) TV needs upgrade.
Get upgrade on the internet onto a USB flash drive. The file may be a ZIP file, if so, unzip to a folder in PC then put the file to the USB drive.
Turn TV on, plug in the USB drive, wait til the upgrade is finished. Unplug USB drive, turn TV off w/remote.
The TV will then turn on by its self and the upgrade is complete.
Hope this works
Few water drops in the TV - 1997 Magnavox
check the vertical section,look for burn resistor or try replacing the vertical ic.
1helpful
No sound or picture on magnavox tv
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
