Expert
- Posted on Apr 28, 2010
Re: Dropped my netbook, restarted it, windows wont...
You might have dislodged the drive and or memory sticks, turn comp over and remove the 2 or 3 panels, you will see the drive and the memory sticks just gently push them back into place and reattach cover panels.
hope this helps
rear, near the batter pack,
This could already be a hardware problem. What is the brand and model of your netbook? When you turn it on where you able to see the windows logo? how bout the bios splashscreen? Do the following steps just for a check. 1) Remove the battery and the power connection. 2) Press and hold the power button for about 10 seconds. 3) Reconnect the power connection. Do not connect the battery. 4) Turn it back on. (Did it go into windows?) 5) Disconnect the power. connect the battery. 6) Turn it back on. (Did it go into windows?) Tell me all the details as to what you could see from the screen. Thank you.
You very well may have damaged internal components. Where did it impact on the case
