Question about Kodak EasyShare Z612 Digital Camera
I have a sandisk sdhc card but it wont format on my kodak easyshare z612 camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
The Z612 uses SD or MMC cards. It will not accept SDHC cards. You'll need to use cards 2GB and smaller.
Posted on Apr 28, 2010
Sdhc card will not format
What type and size memory card? The Z612 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Jul 01, 2013 | Kodak EasyShare Z612 Digital Camera
HOW do I format SD cards for Easyshare Z612? Can I use a "PNY 4GB SDHC card?"
You can Format by entering the camera's menu and find the format section. Click Here and see Pages 36-39 for detailed instructions on formatting your SD Card. Also your camera is not capable of reading the High Capacity SD cards (SDHC) so you will have to stick to the SD cards (2gb or smaller)
Jun 20, 2011 | Kodak EasyShare Z612 Digital Camera
I bougth a 4GB SDHC for my kodak easyhare Z612 my problem is i coudnt format
The Z612 works with MMC and SD cards. It does not work with SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible.
Dec 27, 2010 | Kodak EasyShare Z612 Digital Camera
I cannot format the sandisk Ultra on my Kodak easy share camera. pdavis610@triad.rr.com
The Ultra card is larger than 2GB, isn't it? The Z612 uses SD cards. If your card is larger than 2GB then it's not an SD card but an SDHC (Secure Digital High Capacity) card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller in the Z612.
Nov 24, 2010 | Kodak EasyShare Z612 Digital Camera
How do i format a kodak memory card 4 gb sdhc for my kodak easy share z612
Unfortunately. you don't. The Z612 works with SD cards, not SDHC cards. You're limited to cards 2GB and smaller.
Jun 14, 2010 | Kodak EasyShare Z612 Digital Camera
I bought a new 8GB memory card for my kodak easyshare Z612. However it's not formatting. Help!!
The Z612 works with SD cards, which max out at 2GB. It will not work with larger SDHC cards.
May 20, 2010 | Kodak EasyShare Z612 Digital Camera
EasyShare Z612 Digital Camera: I bought a new 8GB memory card for my kodak easysh...
May 18, 2010 | Kodak EasyShare Z612 Digital Camera
Kodak EasyShare Z612 will not format SDHC 4.0 GB card.
Z612 is not compatible with SDHC card., the compatible and recommended Memory card you can only used is 1GB SD card or 2GB SD card. Gudluck!
Nov 03, 2009 | Kodak EasyShare Z612 Digital Camera
Kodak EasyShare Z612 Digital Camera Logo
670 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
