Fog/Driving Light Bulb Size: 880
Here is the rest of the bulb size used in your Montana.
2000 Pontiac Montana Auto Light Bulb Diagram
Low Beam Headlight Bulb Size: 9004
High Beam Headlamp Light Bulb Size: 9004
Parking Light Bulb Size: 4157NALL
Front Turn Signal Light Bulb Size: 4157NALL
Rear Turn Signal Light Bulb Size: 3156
Tail Light Bulb Size: 3057
Stop Light Bulb Size: 3057
High Mount Stop Light Bulb Size: Assembly
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 3156
Front Sidemarker Light Bulb Size: 194
Ash Tray Light Bulb Size: 558
Glove Box Light Bulb Size: 194
Map Light Bulb Size: 168
Dome Light Bulb Size: 562
Step/Courtesy Light Bulb Size: 168
Trunk/Cargo Area Light Bulb Size: 212-2
Daytime Running Light Bulb Size: 3157NALL
Thank you for using fixya.
Check the Amps on your Fusebox for your brake light if the correct amp measurement is installed for the break lights then consider using a larger bulb or a bulb that can handle more voltage. most likely incorrect voltage is going to the bulb this is normally fixed by adjust the fuse amp amount to be lower or higher or changing the bulb voltage size
