Water overflows and doesn't stop when full. Just replaced the belt 2 days ago and had to lay washer down on back to replace the belt. Before that the washer did regulate the water flow.
There is a small clear hose that connects to the side of the tub near the bottom, the other end of the hose connects to a switch in the console behind the knob for the load size, this tube either came off while you were working on it or it got full of water. If it came off simply put back on but do so with the tub empty of water, this is very important!!
If the tube was filled with water, drain the tub and blow through the tube and reconnect.
· Screwdriver,Flashlight,Voltmeter,Wrenches,Bucket,Rags or mop.
