Question about Envision A17W221 Television
A17w221 goes off automatically with power on
Turn it on I can see the picture displayed for a split second and it goes to black. The functions all work, if the source was cable. I can hit the channel button twenty times while its still black. For an example that is, there is no limit to the functions after the screen is black. And when I turn it off and back on. The channel would have changed from 3 to 23. Its like the tv works perfect but won't let the picture display for more than 2 seconds tops. The power light stays on. I'm puzzled. Theres no input that it won't display on. I have hooked different equipment from computers, to dvd players. No matter what it is, the picture displays for a split second and then nothing. straight to a black screen. Just long enough for the AV1/S-Video/AV2/3 to go away. and its just black. As long as I see the input in the top right corner I see a perfect picture for that split second. Any ideas?
  • brjenkinsjr Nov 20, 2008
    Same for me. No picture after 1-5 seconds.
I have the same problem. The next stage is that the picture won't come on at all and the blue light will constantly blink. I think the light source is bad. Noit sure though.
Posted on Apr 21, 2008
6ya staff
SOURCE:
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
Hi, I have just bought the Fuji JX530. When I take a picture I get a split second clicking sound coming from the lens before the flash goes and the picture is taken. The picture is fine and the...
When you press the button, the camera performs many functions in a split second such as set the focus, set the aperture and shutter speed, calculate the flash power, etc. It will make sounds and if the pictures are fine, then all is well.
Jan 05, 2011 | Cameras
When i load call of duty black ops the screen splits into 2 horizontal screens ......dosent do it with any other games i have
Go to your display settings and instead of choosing automatic for display choose custom. The 3D option is splitting your picture horizontally.
Nov 26, 2010 | Activision Video Game Consoles & Games
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the...
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Smart Modular SV3170A
My monitor showes for a split second then goes black
First, can you attach another monitor to the computer to check to see if it works?
If it does, then your monitor is going bad. Possibly the power supply.
If a second monitor acts the same way, then it's your video card.
Dec 10, 2009 | Computers & Internet
Got an alpine cda 9855 the screen keeps goin black but if you touch the button it comes back on it has like a 5 sec delay then it goes black but still plays any help
Blackout Display Mode: When the Blackout mode is activated, the display turns off to reduce power consumption. The additional power made available by turning off the display helps enhance sound quality. If a button is pressed during the Blackout mode, the display will illuminate for 5 seconds before blacking out again. Blackout Mode On and Off (CDA-9855 only) When Blackout mode is turned on, the display will turn off to reduce power consumption. This additional power enhances the sound quality. Press and hold FUNC. for at least 2 seconds to activate the blackout mode. The display will turn off. If any button on the unit is pressed during the blackout mode, the function will be displayed for 5 seconds to show the operation before returning to Blackout mode. To cancel Blackout mode, press and hold FUNC. for at least 2 seconds.
Copied from the alpine user manual..
Hope this helps
Aug 01, 2009 | Alpine Car Audio & Video
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Screen flashes only for a split-second (as a second display for an iMac)
The inverter is faulty.If your Monitor is powered by a mains'kettle' type lead,then it MAY be repairable,provided you can find someone to do it.If you have an external power supply,then the chances are you have a separate inverter,and it is doubtful whetther you can find the fault or a replacement circuit board....which is why we have become a throw away nation !!
HELP
The AOC Envision A17W221 only has a NTSC tuner (analog). If you are using an OTA antenna, you probably need a digital (ATSC) to NTSC converter box to get any TV signals. These include the ones sold with the government coupon at the switchover. Very few analog stations still broadcast; they were limited to low power transmitters. Thus you need to be close to the transmitter to receive a watchable TV program. For the best signal to the AOC A17W221, connect the component video out on the converter box to the component in on the TV. The specifications for the A17W221 are available on the Amazon sale page, https://www.amazon.com/International-A17W221-17-Inch-HD-Ready-Panel/dp/B0009IRHL8/ref=cm_cr_arp_d_product_top?ie=UTF8 . This monitor is no longer available from Amazon but the site is still there. Newegg also has the specifications for this monitor.
Unfortunately, I can't find the manual for the A17W221. AOC only lists a few manuals for current models. These are available here: http://www.aocmonitorap.com/my/user_manual.php .
I hope this helps. To check for available stations in your area, use a site like antennaweb.org or tvfool.com. Antennaweb gives very conservative estimates on stations that you should be able to receive with an external antenna.
Nov 17, 2017 | AOC A17W221 17 in. HD-Ready LCD Television
Envision A17W221 Television Logo
636 people viewed this question
Top Envision Televison & Video Experts
Ekse
Chris Martin
Chris Martin
Level 1 Expert
Are you an Envision Televison and Video Expert? Answer questions, earn points and help others
