Toshiba Tecra M5-S433 Notebook Logo
Posted on Mar 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A locked bios password on techra m5
Locked bios password on techra m5
  • 2 more comments
  • kaderd Apr 27, 2008
    HI
    I have a TOshiba Laptop u200 that is Bios password protected. It doesnot boot from any device, CD or flopy. I opened it and remove the battery but it is still asking for the password. SOme suggest to use a program,,but this is not possible, because the laptop cant run anything, it stops at the Bios password, unless you have the right one, it did stops immediately after one try.
    thx for helping
  • ade4la Jul 01, 2008
    I have techra A8-EZ8512 when ever i power it a blank page comes up and instructed me to type my password which i forgot pls help me out.
    THANKS
  • Anonymous Jul 05, 2008
    Hi, do you have find a solution, I have the same trouble with a second hand laptop (tecra m5 to). toshiba ask me 250$ to remove the password.. I haven't found a solution on the web (arffff ... google is not my friend this time !) and you ?
    Greg
  • ranjsol Jul 09, 2008
    how to reset bios password on tecra M5, have tried removing battery but dosent work.
    Please somebody let me have the solution to this.
    Regards
    Ranj
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4855
Points
Hello guys
For the password to be removed the battery will not remove the password the only way to remove it is by hardware on this laptop or you can contact Toshiba with the challenge code.
1. At the BIOS password prompt ("PASSWORD = "), press and release the following keys, one after another:
Ctrl, Tab, Ctrl, Enter
The computer's response should be:
PC Serial No.= XXXXXXXXX
Challenge Code= XXXXX XXXXX XXXXX XXXXX XXXXX
Response Code=
if you have any questions please email me or check my forum www.biosmasters.com/Forum1/index.php
Anonymous
Level 2:
President:
  • Expert 1,257 Answers
  • Posted on Nov 17, 2008
Anonymous
Expert
Level 2:
President:
Answers
1257
Questions
Helped
1179434
Points
168
Anonymous
Level 1:
  • Posted on Jul 05, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4855
Points
Please, don't post if you don't know the soluce for this kind of protection. Maybe 'silveradoman' could explain us how we can use a software when the laptop ask us the pasword before the boot sequence... and s4u311, if you knew the solution, you knew that removing batt doesn't change anything with kind of laptop. tks
Anonymous
Level 3:
  • Master 813 Answers
  • Posted on Mar 25, 2008
Anonymous
Master
Level 3:
Answers
813
Questions
6
Helped
352698
Points
2058
U have to reset your bious password by removing bios bettry
open your laptop there was bois batty remove it for 5 min
then after put it back then go in a bios
your prob will solve
Anonymous
Level 2:
  • Expert 58 Answers
Anonymous
Expert
Level 2:
Answers
58
Questions
Helped
24151
Points
135
If removing the battery doesnt work you could try a program called "cmospwd-5.0".Also there is a newsletter called "WXPNEWS" that just had an article about aother programs for passwords.
Bought 2nd hand off ebay but cant get into bios as password required
Tecra M5-S4333 Support ' Toshiba
support.toshiba.com/support/modelHome?freeText=1671279
ToshibaThe Official Toshiba Support Website provides support for Tecra M5-S4333.Missing: unlock
Bios locked
I can't find a decent manual for your laptop but there will be 2 pins on the motherboard that will say BIOS Clear. Short these 2 pins and turn the computer on. This is the only way to bypass the BIOS password. This operation will clear the BIOS and reset to factory defaults. After the BIOS is cleared, turn the computer off and take off the short.
1helpful
Unlock bios
If you need the BIOS password and you don't have it the only way to access it is to clear the BIOS. Since this is a notebook computer this will involve removing the main battery, disassembling a part of the laptop, and disconnecting the BIOS backup battery. Once the battery has been disconnected and reconnected it should have cleared the password on the BIOS.
3helpful
2answers
Need Original BIOS for G31T-M5 V:1.0
So search for the PC model instead of mobo.
2helpful
2answers
Please can you urgently tell me how to start my computer in safemode it is a techra M5
Restart the computer, then when you see the toshiba screen, start tapping that f8 key. It should give you a screen to choose modes. If that doesn't work, only press it once during or after the toshiba screen.
Please rate if this helps!
How do i remove password on the bios of Toshiba tecra m5 laptop
The password exists to protect you, should a thief be in possession of your computer, and he/she tries to use your computer.
So, if you know the current password, you can enter BIOS SETUP, and change the password to "blank".
If you don't know the password, find the original sales-receipt, to prove that you are the owner, and telephone Toshiba, for assistance in bypassing the password.
Set hard drive password toshiba techra 9100
hi
1) it is very risky to unlock it on your own .it involves shorting of pins on the motherboard (remove the Cmos battery and put it after 1min)
clear the password
OR
2) using software www.hddunlock.com to to unlock the harddisk
OR
3) just got to a Toshiba authorized service center and get it Fixed
my friend was charged Rs.1000
Was given the laptop as a gift from a dead friends mother. have turned it on and it asks for a password which i dont know and have been told by a so called expert it is the eeprom. the laptop is a toshiba...
that is a bios password. if you bring it to a toshiba authorized service provider they should reset it for $50. Tecra's require a response code only given to toshiba asp's
I have forget my bios password on toshiba tecra m5 laptop
you have to call Toshiba technical support, there are no reset Bios utilities for a Toshiba laptop
Tecra
If that is the power on password (BIOS) password, that can be removed by a repair center authorized by Toshiba for Toshiba laptops. If you are referring to the Windows password, that can be removed using full system recovery (like reformatting and reloading of the operating system and original programs and drivers) but you need to have the recovery disk for it. You can call Toshiba to check if you can purchase the recovery disks for it. Hope this helps. Thank you.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
