Columbia All Sport Digital watch Logo
Posted on May 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Directions The print in your manual is too small to see. I need to know how to set up my watch and how to use the timer settings
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on May 02, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1291799
Points
7081
If there is nobody who canhelp you directly, try having your instructions scanned into a computer and printed out at a larger size to make them visible!
2answers
I need to know how to set timer for Adidas Ad0297107
There is single manual for all adidas watches. You can find procedure for your watch.
ADIDAS-ORIGINALS-TIMEPIECES_CARE-MANUALS_EN.pdf (adidaswatches.com)
Steve Madden LED touchscreen watch
To change the date and time on your Steve Madden LED touchscreen watch, you will need to follow the instructions in the user manual that came with the watch. If you do not have the user manual, you may be able to find information on how to set the time and date online or by contacting Steve Madden customer support.
To set the time and date on most LED touchscreen watches, you will need to press and hold a button on the side of the watch for a few seconds until the time and date display appears. You can then use the buttons on the side of the watch to set the time and date. The specific buttons you will need to use and the sequence for setting the time and date may vary depending on the make and model of your watch.
As for the timer, you will also need to refer to the user manual for instructions on how to use it. The timer function may be accessed through the watch's main menu or by pressing a dedicated button on the side of the watch. Again, the specific steps for using the timer will depend on the make and model of your watch.
If you are unable to find the user manual or are unable to set the time and date or use the timer function, it is recommended to contact Steve Madden customer support for assistance. They will be able to provide you with specific instructions for your watch.
Dec 25, 2022 • The Watches
Instructions for Eddie Bauer watch lg light up 3 eye 0058 CE
Here are some general instructions that may help you with your watch:
  1. To set the time, locate the crown (a small knob or button) on the side of the watch. Turn the crown to the right to advance the time, and to the left to go back.
  2. To set the date, locate the crown and pull it out one notch. Turn the crown to the right to advance the date, and to the left to go back. When you are finished setting the date, push the crown back in to secure it.
  3. The two small dials in the watch face are most likely used to track additional functions, such as a second time zone or a countdown timer. Refer to the watch manual for specific instructions on how to use these functions.
  4. To activate the light-up feature, press the button or knob on the side of the watch. This will cause the watch hands and dials to light up, making it easier to read the time in low light conditions. The light will turn off automatically after a few seconds.
Dec 15, 2022 • LG Watches
1helpful
I need to set my digital Casio wrist watch. The printing is small. in the I can't read it. uses terms like "city code" that I'don't understand..Also can't set day or date, advice?
If you go on the Casio website and click on the relevant links you can download a manual for your particular watch which will tell you how to set it up.
http://world.casio.com/support/
How do i program?
I bought a Utilitech #0192775 self-adjusting wall timer to regulate some window candles. I want to simply set it to come on from dusk to dawn, and have followed their directions the best I can. However, it does not work. Even some of the steps in the instructions are not on this model, so it is impossible to follow their directions to the "t". Do you know how to get this wall-timer to do what it says it will do? Thank you!!
Nov 30, 2012 • Watches
41helpful
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 • Watches
Don't know how to set up the watch,need directions
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Setting watch after battery replacement unable to set watch
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Make it as big as you need.
Hope this tip helps
R/
David
Need manual
Timer Setting
1. In timer mode press and hold "reset" to enter setting mode; hour will begin flashing
2.Press "st/stop" to increase hours;
3. press "mode" to advance to next setting value
cheers!
Apr 21, 2009 • Watches
Want to know how to opperate
Follow this link and find the instructions:
http://www.citizenwatch.com/COA/English/settings.asp
Do not forget to rate, please.
Top Columbia Watches Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Samuel Osungbohun
Samuel Osungbohun
Level 1 Expert
Are you a Columbia Watch Expert? Answer questions, earn points and help others
