LG WM2101HW 4.0 cu.ft. Washer Logo
Posted on May 02, 2010
LG wm2101hw 4.0 cu.ft front load washer is leaking water out vent in back of washer. Yes, the vent that exits the rear panel of the washer.
  • Anonymous Mar 23, 2014
    water leaking out of vent in back of washer
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1416
Points
Same problem. LG stated I am using too much soap. Cant be because it still does it with no soap. Also have issues with spinning on bed comforter and also drum will not drain. I can wring out a 16oz of water from a cotton shirt sitting in the bottom of drum when completed. Floor is flooded and I am **********. Bought in April 2010 and have had 4 techs out to look at it, but there is no problem. Biggest waste of 600 I ever spent.
  • addacus3 Jul 25, 2011
    SAME PROBLEM!
Anonymous
Level 1:
New Friend:
  • Posted on Nov 29, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1416
Points
Same issue. But not noticed due to location of washer, floor damaged. Thought the water damage from old drain pipes. Opened up back of washer, missing pin that keeps shock absorer in place!
My LG WM2101HW washer door will not lock. Sometimes if you shut the door just right, it will work. I ordered and replaces the actually door switch, but it still will not lock. What else can I do?
You say that you replaced the door switch, but you need to check that the spring of the latch hook inside the door is working properly, otherwise it does not hook properly and will cause these problems.
My washing machine makes marks on everything
LG WM2101HW 4.0 cu.ft. Washer Stains clothes ruining ...
www.fixya.com > ... > LG > LG WM2101HW 4.0 cu.ft. Washer
... stains out with anything and they are ruining numerous items of clothing. ... stainson light objects ie making white marks on light blue clothes ruining these ... by greasestains from their front loader Kenmore. .... remove the agitator from a ...
My LG WM2650HWA front load washing machine is 13 months old. A few weeks ago I noticed water at the end of the cycle in the front of the machine. Upon further inspection I noticed soapy, water at the
It's very common for the sump hose to have a hole in it causing it to leak. The quickest way check is to tip the washer back and examine the sump hose by stretching it, as you stretch the hose you should find your leak. You'll also want to check the door gasket for cuts and the drain pump assembly for leaks. Let me know what you find.
Lg front loader when during the cycle is the bleach dispenced
bleach? do u mean detergent? normally machines run pump/then start to fill.water will pass through drawer then they heat /wash/drain/spin then refil for rinse conditioner/spin rinse drain fast spin end pretty much
Where is the serial number on the machine? We have a front loading LG washing machine.
When you open the door it should be on a 2" x 3" white sticker around the door opeing
4 mo. old. leaking water and suds all over floor. using he detergent.
If its leaking by that amount there will almost certainly be a pipe that has pulled loose somewhere at the soap box due to the soap suds leaking over the floor. To see the workings, remove the top lid and start a cycle and observe. Go from there.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
