1. Problem is intermitent, mute button is OK, volume is always in same position.
2. TV will play fine then 3 hrs 15 min then no sound, then sound comes back,then goes again 10 to 15 min then comes back for 10 min then goes again.
What should I check to hopely solve my problem?
What are you using to connect to the monitor? Have you tried replacing the cable, sometimes cheaper HDMI cables can cause this issue
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
SOURCE: monitor doesn't work
I'd try this monitor on a spare computer. It sounds like the video card (motherboard integrated or otherwise)is not putting out any video information or missing sync signals. The monitor must receive these signals or it will go into standy/sleep mode. If the computer has integrated (on motherboard) video, check your bios settings to see if it is properly enabled. If it has a slot video board, then try a different video board. Your present board might be dead. Another possibility is a bad cable connection. check the connectors for bent pins. Assuming the connector is the standard HDB-15, it is easy to bend a pin over.
SOURCE: LG W2252 22'' Monitor flicker
it sounds like your a part in your monitor is about to go bad if its still under warranty if not find a repair shop that repairs monitors if by chance you cant find one of them buy a new one
SOURCE: Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
SOURCE: LG 1750s monitor goes into power saver mode in 5-10 min
change the setting in the screen saver option (Power)
or look in Power in control panel...also check the hybernation time
Testimonial: "Settings are not the problem. The problem is with monitor itself and it is not related to operating system."
Volume/Mute Indicator: This
indicator will glow green when the
HK3270 is turned on. Its position
will enable you to judge the relative
volume of the unit even when the
speakers are muted or turned off.
When the indicator is pointing
towards the left, at an "8 o'clock"
position, the volume is low; when
it is pointing to the right, as in a
"3 o'clock" position, the volume is
loud. When the unit has been muted,
pressing the Mute button ïâthe
indicator will flash
