F01- Internal Shorted Cell Battery-(Cannot Be Charged) or
Excessive Load On Battery While Charging (Check Load)
*If this shows it is recommended to take your battery to a certified auto center for evaluation.
This Info Came Directly From The Manual.
Don’t crank motor while it’s charging load draw to high for charger
Depend on what kind of batteries, and how often you are going to use the charger, and for what purpose are going to use it.
If your battery accidentally discharge far from your home a Jump Start is a must. But Car batteries are shallow Cycle and need to be fully charged. If you want to Set and Forget Charger, then a Smart Charger takes care on his one for the battery. Automatically adjust the voltage and turns off when the charge is completed. Has the Reconditioning option, can display the battery voltage, and can check the alternator. Destroying a $120 battery is more expensive than a Smart Charger.
I use a Vector Smart Battery Charger - 2/10/20 AMP 12V fully automatic.
Retail $49.95 I bought on sale CLEARANCE: $29.95
If you have cars not driven in daily bases, or go in vacation, a battery Tender is a good option too.
