I believe that the higher end units have auto reset pressure switches, if you look down the inside of the unit, you will see one or two pressure switches welded to the lines,,,there are about the size of a "C" cell sized battery, with 2 wires running into them, if it is a manual reset type there will be a small rubber coated button on top, between the 2 wires.
If this has been helpful, please rate me, and/or contact me back with any further questions.
Sincerely,
Paul Gibson
SOURCE: My attic Goodman Air Conditioning unit is leaking
There should be a condisant pan under the unit and it will have pvc piped to it to drain away all the water. This gets clogged up on occasion due to dust and mold and debris. It will need to be rodded out with a close hanger or pipe snake. Then you will want to mix-up a solution of 50% bleach and 50% water and pour down it to kill mold and algea.
SOURCE: I can't find the reset
If there is one it is rihgt next to where the copper lines enter the outdoor unit. There should also be a none reszetable fuse on the furnace control board
SOURCE: Goodman air conditioner will not turn on outside
When ever you hear a buzzing like you are hearing means one thing one of the fuses on the outside disconnect box is bad. Only getting 1/2 the power. Find the bad fuse and get the same size and will be good to go. ken
SOURCE: I'm looking for a manual for a Goodman HG31ES air
Go to this site and join w/ your email - download the manual you want for free
http://portablemedia.manualsonline.com/manuals/mfg/insignia/ns-4v17b.html
SOURCE: what type of capacitor comes with a 5 ton Goodman
The best way to know what size capacitor it needs is to look on the label of the fan motor itself. It will tell you the size it needs. Condenser fan motors get replaced all the time with different capacitors needed. If you cant find a label or its too weathered, try to find a model number on the fan motor and any local A/C supply store will be able to look it up. Hope this helps.
