We did this:
Turn player of (standby) and clkick first on the pause and then on the open button.
The player goes out and then standby.
Problem was solved
Would
you like to review the features of the LG LH-D6235 Home Cinema System?
Have
you lost your LG LH-D6235 Home Cinema System Users Guide?
Would
you like a digital, searchable, pdf version of the LG LH-D6235 Home
Cinema System Owners Manual? Follow this link (& click FREE)
to download a pdf version of the LG LH-D6235 Home Cinema System
documentation.
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
With the machine turned off (not off at the mains mind you) press and hold the stop button and then while still holding the stop button, press the eject button. Turn it back on and hey presto! This method will unlock it when its locked and vice versa. p.s its in the manual
Make sure the DVD player is set to 16:9 screen mode.
If you still get the bars at the top & bottom, then its probably because the DVD was filmed in true cinema widescreen, (21.7:9) whereas the TV is only 16:9.
There may be other settings on the DVD player to expnad the picture out, but you will either lose the edges of the picture, or it will be stretched.
a good way to go is to connect the home cinema kit staight to the tv though phono leads, see if your tv has a phono in and out this must not be a av socket. you should then connect it in to your cinema kit so what ever you watch comes though ur cinema system
