Question about Garden
Tractor starts fine on full choke, but as soon as you put it on throttle it cuts out. it also cant sustain it if you engage gear or turn on the blades to start cutting
    Guru:
  • 351 Answers
You may have something stuck in the mower deck. If you nuse a mirror you can look under the deck and see if anything is jammed there. If the blades are jammed it will stall the motor.
Posted on May 04, 2010
6ya staff
SOURCE:
Chokes and Dies when cutting
Adjust the choke or carburetor. In case your chainsaw stalls when the engine is idling, ensure that the choke is set properly. To do so, first try releasing it to adjust it, and then move the plate and tighten all screws once again. To loosen any grit, spray carburetor cleaner spray on the choke's shaft. The carburetor may also need to be adjusted; consult your owner's manual which will guide you on resetting the idle mix screw.
Mar 13, 2014 | Ryobi 940968018 C4620 Label
Engine cuts out when slowing down
Start off by cleaning carbs,sounds like idle jets are blocked
Feb 27, 2014 | Boating
Wheres the choke on a 49cc pocket rocket
The choke is on the carb. Check if the carb set screw is set right, turn it all the way in and then back out 1 1/4 turns. then fine tune by 1/4 turn increments.
Feb 02, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
I charged the battery and there's gas in my lawn
Usually there is a combination choke on the throttle, when you put the throttle all the way up it sets the choke and once the engine fires you idle it downa little to full throttle.
Apr 09, 2010 | Garden
Hard to start lawn tractor
I have 2009 lawn tractor that will not start (from day 1) unless I use a small squirt
of start fluid into the air cleaner area. Nothing else seems to work. The battery will run down before it starts. Once engine is warm it starts great. Love the tractor,
hate the starting problem. Elevation is not a problem in michigan.
Jan 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Jun 02, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
I have trouble starting the tractor
First, make sure you are using fresh gas. Gas breaks down quickly with the ethanol they put in it now.
Next, you must apply the brake before you start the tractor, and be sitting in the seat.
Make sure it is neutral and make sure the blade is not engaged.
Apply the choke, then start the tractor, once the tractor starts running turn off the choke. let the engine run for a bit, then put it to full throttle.
If you get off the seat without the blades off, and the break on, the engine will shut off.
May 03, 2009 | Craftsman Garden
Garden Logo
76 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
