Re: says date/time not set but wont let me set the time...
Broken keypad ribbon. It's because the keypad ribbon is folded over twice and the creases split over time. have a look at my tips page for this problem. It won't help you much I know and the only solution is a replacement membrane.
Press the DATE button on the back of the camera to cycle through date, time, and none (just dashes). Press the shutter release button to set the format.
If you need a manual, you can download one at http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_4/2164_E_B.pdf
If you are familiar with camera repair then apart camera and check navigation switch board is intact with main board of camera. That is only reason of switches no operation in this camera.
The ribbon cable for the buttons has either come out of its socket because it was not locked down (does happen) or it is broken and will need to be replaced. Fuji will not send out spare parts but will fix it for a price. Last quote I got from fuji to fix the keypad ribbon on an F470 was £80. check ebay for donor camera
should be in setup screen. If the date does not hold after a battery change/charge, then your capacitor on the mainboard is bad, it wont affect anything but the date/time and any custom settings you have set. It can be replaced be a camera shop, but it will exceed the cost of the camera in most instances.
Set date and time and camera should work. If camera asks to have date set everytime you take batteries out then the memory 3 volt battery is flat ... replace.
