Question about Akai CF2791 27" TV
Picture but no sound
Akai 27 TV, DVD. TV has picture, no sound. DVD works find and has sound. SAP is off. Mute is off. Pulled plug from wall outlet to reset the TV but this did not work. Any ideas?
    Sergeant:
    Champion:
  • 433 Answers
If you get sound from dvd then you know the audio output circut is good in tv try other video inputs for sound composite component
Posted on May 05, 2010
Restore sound on my Tv, suddenly lost.
  1. Check if the mute button on the cable box/TV/VCR is activated. If so, turn off the mute feature
  2. Verify the volume on the cable box/TV/VCR is not turned all the way down, either by adjusting the volume level on the equipment itself or with the remote control
  3. Check if the TV has an earphone or headphone jack. If so, make sure there are no earphones or headphones plugged into it
  4. Check if the Cable Box/TV/VCR has a SAP/MTS switch (Secondary Audio Program / Multichannel Television Sound). If so, make sure it is set to the proper setting. Consult your TV/VCR manufacturer's user manual for information for your specific TV/VCR. Click here for information on changing this setting on a Cable Box
  5. Check behind ALL TV and equipment (Cable box, TV, VCR, DVD, stereo receivers, etc) and the coax cable at the wall outlet for any loose or damaged connectors
  6. Make sure all equipment and connections are hooked up correctly for the video and audio based on the type of connections being utilized
Mar 10, 2015 | SEG 19 in. TV
Tv picture fine : no sound
Check whether the mute button on TV or remote is jammed. Try using a headphone. Try changing the input device to something you know works for sure. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Sylvania Televison & Video
Dynex 24" lcd led tv
Check to see if mute is on, and through the menu to see is sap is on. Sometimes button are accidentaly pressed. If none of the above, the ntry replaceing your main board.
May 05, 2011 | Dynex DX-LCD37 TV
AKAI 27 Model #LCT2785TA
The message you are seeing means that the tv is not receiving a signal from the source. Try hooking up a different source such as a DVD player or a Cable Box to that same input on the tv. If you have picture and sound then the problem is with the original source. If that does not work then you have a bad Main bd.
Jul 10, 2009 | Televison & Video
Went out no picture sound nothing
no picture no sound nothing but when connect conputer have picture and sound plese help thank
Apr 28, 2009 | Norcent Technologies LT-2722 27 in. LCD...
Akai CF2791 27" TV
I have a troubleshooting procedure file who is in PDF format , i don't know how i can send that to you.
Any way if you are a technician , send me a small message to my email so i will send you all the information attached to the message which i will send back.
Thks
Sep 24, 2008 | Akai Televison & Video
Toshiba CX32G60 32" picture, but no sound
your audio is set to (sap)
press mts button on the remote unite until it display the word stereo
Mar 30, 2008 | Toshiba CX32G60 32" TV
Problems with Emerson EWC27T3 27 in. TV/VCR/DVD Combo
You'll need to set your audio options to back to normal, not SAP...accordianman
Oct 12, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
NO Picture in Color except for PIP
have a tech check your tv the color circuit needs to be looked upon.good luck
Apr 29, 2007 | Akai PT5492S 54" Rear Projection...
Some channels have no sound some are in spanish
With your remote, go into the menu, find the audio setup and click off the SAP. Thats the Second Audio Program. Some Broadcasters send a second lanquage along with the regular audio. Someone must have been looking around or playing with the remote and turned on the SAP.. Good Luck PS please do not forget to rate this thread
Oct 18, 2006 | Orion STV2763 27" TV
Akai CF2791 27" TV Logo
384 people viewed this question
Top Akai Televison & Video Experts
KISHORE DESHPANDE
Ekse
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
