Blank copies?All sorts of things can cause that, for instance... Drive to drum broken but paper is being pushed through, same with developer system.Does the machine have "corotron wires" (the wire that charges the drum, then transfers the toner image to the paper?) Check these wires are intact.Is high voltage being applied to these wires? Is there a paper clip stuck in the transfer corotron- it HAS happened-it shorts out the HV so there's no transfer current... even a piece of paper can find its way between the drum and corotron and the copy paper can slide through and not be printed on! Not sure what you mean by"no any toner or drum it has"? Does the exposure lamp come on...usually has a fault code if this fails, so unlikely So...the problem is almost certainly related to drum /toner /development/high voltage areas
