HP PSC 1610 All-In-One InkJet Printer Logo
Posted on May 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
To print photos my machine requires a memory card. What card should I ask for and where/how do I install it?
Anonymous
Level 2:
  • Expert 232 Answers
  • Posted on May 08, 2010
Anonymous
Expert
Level 2:
Answers
232
Questions
Helped
105684
Points
676
Hello!
You can print photos from your computer too. Usually, people use memory cards from their digital camera, when they want to print photos directly from the memory card. If you do not have a digital camera or any other device that uses a memory card (i.e. a mobile phone), I am not sure you need one in order to print photos. However, here is the answer to your question:
You can use several memory cards in your printer, but only one memory card at a time! You can use:
  • SmartMedia, xD-Picture Card (fits in bottom right of the slot)
  • Memory Stick, Magic Gate Memory Stick, Memory Stick Duo (with user-supplied adapter), Memory Stick Pro
  • CompactFlash (I, II)
  • Secure Digital, MultiMediaCard (MMC)
Here is a picture, so you can see how to install them:
You can buy either one of these memory cards, it's up to you to decide which one you want.
Hope that helps!
Nikon coolpix l110 usb cable not connecting
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
tip
Copy Pictures From INTERNAL MEMORY to Memory Card (solution for those who have...
Required:
Samsung D53 Camera
Memory Card (Clean with no pictures on it!)
Fresh batteries
Optional:
Computer
Memory card reader on your computer
Problem:
You have several (or more) photos that were taken with no memory card inserted into the camera, and they have been stored on the camera's internal memory. You have no USB cord to get the pictures off your camera.
Solution:
I don't know if this is in the manual (as this is a used camera I purchased with no manual or USB cord). In my frustration, I accidentally found out how to get my photos off the internal memory and onto my computer's hard drive.
Here are the steps I followed:
1. Ensure fresh batteries are inserted into your camera. You might lose data or get corrupted pictures if the camera dies while you're transferring pictures. Fresh batteries are important.
2. Insert memory card into the camera (where the batteries go) and close the lid.
3. Power camera on.
4. Press the Print/Review button (bottom button to the right of the LCD) once.
5. When you see the words "No Image!" appear, press the Menu/OK button.
6. A new menu will pop up, asking you COPY TO CARD -- use your buttons to highlight "Yes".
7. You will see your camera "Processing!" It will finish on its own, so do not interrupt the task.
(Optional)
8. Once it has finished "Processing!", remove memory card and insert into your computer's memory card reader to see and SAVE your pictures to your computer. Ensure all photos transferred properly before proceeding to Step 9.
9. With the memory card removed from the camera, power the camera back on and delete individual pictures, if you want to reserve internal memory for future emergency picture-taking situations (especially now that you know you can actually get the photos off of the camera's internal memory now!)
2answers
Cannot start Epson easy photo print due to missing files or insufficient memory. Reinstall Epson easy photo print or make sure there is enough available memory
Dear friend,
Check with the Drive that contains the installation files for enough free space.approximately 500 MB Free space required for the SOFTWARE.
Our Canon G9 camera heated up, 2 orange lights started flahing and then stopped working. The memory card now can't be opened on other cameras we have tried. Can the memory card be fixed so we don't lose...
Doesn't sound good -- do you have a memory card reader (one of those little boxes) with about 10 slots for every type of memory card -- put the card into one of those and plus the mini USB into the PC.
OR
A printer like Epson 6000 series - that has a CARD slot for flash or SD.
OR
Take the Memory card into a shop to develop the photo's and ask then to make a CD ROM of the Photo's so you can decide which one to print later on.
Ray
I took a picture without the memory card and the photos got stored on the camera. how do i print these for a coolpix p100?
A couple options:
1) Connect your camera USB connection to your computer/laptop and copy the required photos to your hard disk or other external storage device.
2) Alternatively, plug in a SD card in your camera and transfer the photos from your camera internal memory to your external 'plug-in' SD card via the camera menu option: if required, refer to your camera user manual on how to use this copy function.
Hope it helps.
How to print photos on dx4850 from memory card
DX4850 is not designed to print photo's standalone; epson creativity suite software is required at this link
Once installed (along with printer drivers), a memory card may be inserted into the printer, to be followed by a notification from computer that a new drive is included in the system.
In case of ms-windows, there are two ways to print a document:
1. Select drive (under My Computer) and right click desired file and just select print.
2. Run epson easy photo print software and select file(s) to print and the package will guide you till printout.
As simple as that.
good luck
What happens if you press the shutter button on your camera and you have no memory card installed will you break the camera
According to the manual your camera does have an internal memory, so shooting with no SD card installed will simply result in internal photo storage. Using the camera's MENU you can select or deselect the option to "Shoot w/o card." Selecting ON will store photos in the internal memory, while OFF will divert all photos to the card. Attempting to shoot with the option OFF and no card installed will prevent the camera from taking photos and display a message. I could not find information on the number of photos that can be stored on the internal memory.
Need the manual? You can download/print it here:
http://snpi.dell.com/sna/manuals/A1761803.pdf
Dec 25, 2009 • Cameras
Printing
Jess, is this printer new or out of warranty?
If it is new, just call Epson and raise the issue with them. It sounds like you have a problem with the printer that requires action from Epson. If your computer states the machine is not ready, then something may be faulty.
Check also in the manual that you have not entered a "print photo from card" mode which makes the printer wait for a card to be inserted.
Formatting memory card
Don't even think about formating your memory card ! You need for a data recovery software to recover your pictures. There are a lot of recovery software's at the market and some of them are even for free. Look for it in the internet, under "memory card recovering pictures" Good luck
2answers
Computer can't see photos on memory card after removing to print at auto booth
This is common when you use a memory card that isn't recommended by casio. They only recommend using sandisk, toshiba, panasonic memory cards. Try one of those and you should have no problems.
k24674
Grand Canyon Tech
Grand Canyon Tech
