I have an sony xplod 4 channel 600 watt amp hooked up to an rockford fosgate p1 12. Why when hookin up a sony xplod 10 also in the trunk. Could not get the sony to ht at all. Is amp to small with to many channels or what? I mean the p1 still would hit but the sony would just barely move. Got the rocford bridged on the first 2 channel. Did the same to the sony xplod. But it still will barely move.
First are they in the same box? If so and they are sharing the same air space running one amp to both is best andwill perform better. One woofer could be over powering the other and or you could have a woofer problem. A lso your wiring coul be problem. When amp is bridged it changes the OHM reading and output your other woofer may not be rated at or able to handle a lower Ohm rating also it coul blow that woofer if it hasn't already hapened . Be careful. check woofers independently for operation and check the non performing woofer on an unbridged power source or amp. Hope this helps. Write back if not.
